Question about Kitchen Ranges
Inglis stove door: Put the %^@! back on after cleaning...
Trying to put a stove door (Inglis) back on? any tips?
    Novelist:
  • 184 Answers
SOME HINGES HAVE A HOLE THROUGH THEM TO LOCK THE HINGE IN THE "BROIL STOP POSITION" THAT WILL MAKE IT ALOT EASIER TO REINSTALL THE DOOR. SOME HINGES HAVE A BUILT IN LEVER THAT YOU FOLD INTO THE JOINT OF THE HINGE, LOCKING IT IN PLACE. IF THE HINGE CAME OFF WITH THE DOOR, THERE ARE TWO PINS THAT THE HINGE HAS TO HOOK BACK OVER WHEN INSERTED INTO THE HOLES IN THE FRONT OF THE RANGE. FIND THE CORRECT ANGLE TO ENGAGE THE HINGES CORRECTLY.
IF THE HINGES ARE ATTACHED TO THE RANGE, PULL THEM OPEN TO THE BROIL STOP POSITION. THEY NORMALLY WILL HANG IN THAT POSITION. USE YOUR KNEE TO SUPPORT THE DOOR AS YOU SLIDE IT BACK OVER THE HINGES.
Posted on Mar 31, 2008
How do you set the self cleaning oven for and Inglis superb IRP 34581 and open the door when it is done? I don't have any instructions for this stove
hit "self clean" button, then the start button,, the door will stay locked for about an hour after cleaning ( safety)
Oct 20, 2010 | Kitchen Ranges
GE Profile Self-Cleaning Stove
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 27, 2010 | GE Profile Spectra JGBP79 Gas Kitchen...
Stove Door Lock stuck
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 18, 2010 | Kitchen Ranges
PUTTING STOVE DOOR BACK ON
Since you lifted it off you know that it slides on the spring loaded arms. If you are trying to do it by yourself it may help to have someone hold it while you guide it on. There should be some set screws on the arms you may need to loosen or remove so you can put it on and them replace the screws to hold it in place on the arms.
Feb 28, 2010 | Hotpoint RGB745 Gas Kitchen Range
How to start the cleaning process
If yours is like ours, you hit the clean button and lock the door and close it. The lock is inside the door near the top. You can set it to clean from 2-4 hours with the time set knob. To unlock the door you hold the lock button located under the display panel on the left side and open the door. Hope it helps.
Feb 23, 2010 | Kitchen Ranges
Oven door lock engaged while NOT in cleaning mode with door open
The question isn't that clear as to what your problem is but try unplugging the stove or turning the power off to the stove at your main fuse/breaker box and then turn it back on. You should then have the oven door unlocked
Aug 08, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Need instructions for operating self-cleaning oven on "inglis superb" stove. came with the house, no instruction manual.
It seems that all your "solutiuons" are actually just more questions. I searched for awhile and found NO actual solutions. This renders your sight virtually useless. Or, at the very least, not very user friendly.
Oct 05, 2008 | Kitchen Ranges
Inglis stove wont open oven door
Hello renald6969 ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You aid, You had problems with your main board of my inglis and had to get it repaired by a dummy but you put it in and it shorted your oven door...now you don't know if there is a reset button to open it or if you have to bust it open to release contents inside!
STOP
Try this reset feature and see if I can help you open it.
1.Turn everything of on the range and oven.
2.Go to the breaker and turn it off for 5 minutes.
3. Turn the breaker on.
Now lets see if this procedure reset the system and released the oven door lock!
Let me know!
Do not break it open!
I'm here tonight .
Just let me know!
What is the model number and
How old is this electric range?
I am Huuum
Please do not forget to leave a rating before you sign of!
Sep 23, 2008 | Kitchen Ranges
Frigidaire stove door locked
I've had a similar problem - door is locked. If the door is open - locate the light switch and hold it in for a few seconds. Sometimes it makes a noise and resets the lock. Otherwise, push the Clean button and the Cancel button on front of oven simultaneously and hold for about 30 seconds. The ?locked? light should disappear. If it is working, you?ll hear a mechanical hum as it resets.
May 10, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Jennair stove door locked
there is a thermostat on rear of oven that has gone bad.Unplug unit remove back panel and you will find it there.You can also undo your locking mech. and put back togather to get door open.
Mar 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
731 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
