Question about Microwave Ovens
R1381 Sharp Carousel over the range microwave
We are trying to install ANOTHER brand of microwave and cannot get the Sharp Carousel off the wall. Do we "lift" it up, pull it out, or just put a bomb in it?
belottlady
  • thecip255 Mar 28, 2009
    What models can you replace on that same mounting plate for the R1381 Sharp Carousel?
I know this is late, but I have instructions for this unit. Remove the grease filters on the bottom. Inside the exposed hole there should be two gold colored bars. These are attached to plates at the top of the until which hook onto the mounting plate. Undo the screws at the bottoms of the bars and pull them down. This will unhook the unit from the top of the wall plate. Roll the unit forward and unhook from wall plate.
Posted on Feb 18, 2009
  • AAAA
    AAAA Dec 20, 2013
    ADMGRINDER: YOU ROCK MAN! THANK YOU. I GOT IT OUT!!!
  • Microwave Ovens Master
  • 9,098 Answers
Although not that exact one, we have two older Sharp installation manuals on our site.
Maybe one of them will be close enough to yours to do the job.
They are here and here.
Posted on Apr 01, 2008
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
Sharp Carousel 2 R-8475A
power to microwave gone wall switch has 120 volts
May 09, 2014 | Sharp R-9H84B Microwave Oven
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Jul 07, 2010 | Sharp R-303CW Convection / Microwave Oven
I have a Sharp Carousel over the range microwave model R -1601. I cleaned it and now it sparks when we try to use it. What can I do to fix this problem?
The cleaning operation may have spread metal particles or other conductive materials on the walls/floor of the cooking cavity. Try wiping the entire cavity with a damp, clean cloth, then heat a cup of water for a test. Hope this helps!
May 24, 2010 | Microwave Ovens
Sharp carousel 1993 r1420b, how to remove from
One of these installation manuals may be close enough to yours to help you: manual 1 | manual 2 | manual 3
Dec 27, 2009 | Sharp Microwave Ovens
Need wiring diagram for sharp carousel microwave model r-1491
I found one for mind on the inside of the outside cover caseing. just need to unmount from wall and remove the six screws of the back to remove it.
Nov 13, 2009 | Sharp R-1491 Microwave Oven
Wattage Sharp Microwave Ovens Carousel Model R-3A35
i just checked my R-3A36 manual to find out the wattage. it's 800 watts. i make pralines in my microwave. i am always asked for the recipe. so i needed to be able to tell people the wattage of my oven so they can adjust the recipe to their oven.
garry, metairie,la.
Oct 06, 2009 | Sharp Microwave Ovens
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
May 29, 2009 | Microwave Ovens
Microwave removal
Actually, you shouldn't need to remove it from the wall to change the door switches or latch head.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We have a partial service manual for that unit at our site, and it has the wiring diagram (helpful to be sure it all gets back right).
The manual is at http://www.microwavedisplay.com/r1380_r1381_sm.pdf
Feel free to contact me directly if you have other questions.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 31, 2008 | Microwave Ovens
Microwave Ovens Logo
5,077 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
