Question about Broadcom BCM94306MP - IEEE 802.11b/g Wireless Internal Mini-PCI Card (BCM94306MPWIRELESS)
Download detects networks
But need to be right up against wireless modem to get connected
  • 1 more comment
  • whooaah Apr 02, 2008
    all connection secure
    6 networks seen, yes i connect to strongest, no other devices, not known when problem started
    thanks for the help
    Sergeant:
  • 313 Answers
Usually when this happens the antenna wire connections have come dislodged. Did you put this in recently? Has the laptop been dropped? The internal antenna wires snap onto this type of internal wireless card and not always snap on secure. THat would be the 1st thing to check.
Posted on Apr 02, 2008
  • Hollyecho Montgomery
    Hollyecho Montgomery Apr 02, 2008
    When you look at available networks, how many do you see? Are you connected to the strongest one? Do you have any other wireless devices that connect to that router? When did this start happening?
    I am then at a loss to help, I am sorry.
Can't start my wireless modem
I think the problem is you cannot connect to the internet wirelessly using your laptop. The problem may lie in the modem or in the laptop itself.
First you need to isolate the problem. That is, determine if the laptop or your modem is the one that has the problem. If you can connect to the internet using your laptop in someone elses home network or free wifi outside your home, then the problem is your modem. BTW, modems don't have the capability to connect wireless devices to the internet. You need a wireless router. If what you have is a router, you're on the right track.
If your laptop can detect your home network, try connecting to it. If you're getting an error, call your Internet Service Provider. They should be able to help you fix the problem. Also, try updating the driver of your laptop's wireless card. You can do this by hardwiring your laptop onto your router, go to device manager, right click on your wireless card, then hit update driver. If nothing works, call your laptop's OEM.
Sep 28, 2011 | Lenovo ThinkPad R60 with Wireless Wide...
How do i connect my net book to use my wireless router
How do you connect your wireless router to your netbook..?
you must have an internet connection with your service provider or isp(internet service provider),...
connect it with your wireless router modem, or modem to wireless router to your wifi laptop,.
make sure power of your modem and wireless router is on there was an ac power cord it needs to be plug...
next in to your laptop install the wifi driver,... to know that it is intalled go to my computer(windows xp/?)right click then properties go to harware tab then device driver look for yellow ? and intall driver if necessary that your wireless connection driver is not install...
if done and install go to start menu then connect to --> show all connection--> wireless connection and done it will connect... sometimes theres a security u need to type wep key,, etc etc..
HOPE IT HELPS!!!
Jun 27, 2011 | Sylvania G-Netbook
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
I have connected my wlan connection. but still bsnl gets connected only through lan. if lan is unplugged it is not connecting through wireless though the wireless connection shows as connected
Connecting to the Internet using a router
  1. Choose a convenient location to begin installing your router, such as an open floor space or table. This does not need to be the permanent location of the router. For wireless routers, it may be necessary to re-position the unit after installing it as the signals may not reach all areas needed.
  2. Unplug the power to your Internet modem.
  3. Power down your computer(s).
  4. Plug the power in to your router.
  5. Connect your Internet modem to the router. The cable plugs into the router jack named "WAN" or "Internet". Turn on your Modem.
  6. Connect one computer to the router. Even if the router is a wireless model, connect this first computer to the router via a network cable.
  7. Turn on the computer.
  8. From the computer connected to the router, open your web browser. Enter the router's address, http://192.168.2.1, and press Enter on your keyboard.
  9. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  10. To configure the router to connect to the Internet, you must enter information provided by your Internet Service Provider (ISP) into the "Connection Type" section in the left-hand column under the "Internet WAN" heading of the router's configuration page. If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address by your provider, the static IP fields (including network mask and gateway) must also must be set in the router.
  11. If this is a wireless router, change the network name (referred to as SSID). While the router comes to you with a network name set at the factory, you may want to use something more familiar for your network. Read Changing the router's wireless channel and SSID for a description of this process.
  12. Plug the power back into your Internet modem.
  13. Verify that this computer can connect to the Internet properly. Open a new web browser and visit a few Internet sites such as Google.com or Yahoo.com.
  14. Finally, configure additional network security features as desired to guard your systems against Internet attackers.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Belkin (F5D7231-4) Wireless Router
How to configure a wireless connection
Hi friend,
firstly make sure if you user Windows XP , you install service pack 3 in your system before the wireless configuration,this is not necessary but it protect your system  against hackers,If you user Windows Vista you need to install Service pack 1.
many wireless technologis in market like 802.11a and 802.11g,most popular is 802.11g.firstly you need some necessary equipment for wireless network technology-
1-Wireless router
2-wireless network adapter
3- Broadband Internet connection
firstly unplug the cable modem,connect your wireless router to your modem,your computer will through wireless connect to your router, and the router will send communications through your modem to the Internet.
turn on the system and open Internet Explorer and type in the address to configure your router.You might be prompted for a password. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router.
The exact steps you follow to configure these settings will vary depending on the type of router you have. After each configuration setting, be sure to click Save Settings, Apply, or OK to save your changes.
I think this is helpful to you.
Thanks,
Jan 07, 2010 | IBM ThinkPad T41 Notebook
Comunication between modem and wireless is not working
First you need to make sure that your modem alone is working right. you can check this by connecting your computer directly to the modem and testing for the internet connectivity.
Then power off everything. connect the ether net cable from the modem to the router. connect both the power cables (modem and router). power the modem first, wait for a minute and then power the router. this should work
Sep 18, 2009 | Linksys Wireless-G WRT54G Router
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
My computer was wireless until I changed modems becausethe old one stoppd working
If you are using Windows XP, you go to start --> control panel --> network connections --> right click on wireless network connections & go to properties --> go to wireless network tab --> delete / remove all the networks under preferred network box then click on view available wireless or configure then connect to your network by clicking on the name of your modem --> type in the wireless password.
May 01, 2009 | 2wire (1000-000057-000) Modem
How can create a wifi connection with my siemiens speedstream 4100 modem
You need to purchase a wireless router, and install it right after the modem.
Your Direct connect PCs would connect via ethernet cable, and wireless cards - wirelessly.
Jan 09, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Broadcom BCM94306MP - IEEE 802.11b/g Wireless Internal Mini-PCI Card (BCM94306MPWIRELESS) Logo
51 people viewed this question
Top Broadcom Computers & Internet Experts
Prashant M
Prashant M
Laxman Bisht
Laxman Bisht
Computer Links
Are you a Broadcom Computer and Internet Expert? Answer questions, earn points and help others
