Question about Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL11
Water drips into washer after cycle is complete.
  • 2 more comments
  • JordansDad Apr 04, 2008
    Same problem as described above. After the wash cycle is complete water keeps dripping into the tub. I shut the cold water supply and the drip stops. I unplugged washer and plugged back in hoping the valve would shut. No help. The washer is just over warranty at 2 yrs and 1 month. Any help would be appreciated. Thanks
  • Anonymous Apr 28, 2008
    during and after the cycle, water drips from the fill tube, soaking the spun dry cloths inside. Clothes must be respun if left in tub for any period of time. Is the plastic fill tube malfunctioning or maybe worn out? I took it apart to look it over but I don't see any obvious cracks or worn spots?
  • Anonymous May 04, 2008
    it sounds like your solenoid valves inside the washer are sticking (not all the way closed) and needs to be removed and cleaned and operated a few times whilst outside of the machine, it will eventually come good normally. This is a normal wear and tear issue that I've noticed on my washing machines, except I usually get it so the machine doesnt fill at all or very little water flow comes through during the filling cycles. Julian.
  • Anonymous Jul 26, 2008
    Water drips onto freshly washed spun clothes soaking them.
    Problem Solver:
  • 13 Answers
I suspect it is a solenoid valve inside the machine bypassing. It does sound like the solenoid valve is not closing properly (not fully seating in the closed position). The solenoids need to be removed, cleaned out and operated a few times, and see how that goes. I get a similar problem on my washing machine but normally the symptoms are not enough water flow coming into the machine when filling. I suspect this is due to the hard water supply we have here in Whyalla SA. good luck! Julian.
Posted on May 04, 2008
After several loads, the drip stopped. I'd guess a valve was not closing completely.
Posted on Apr 01, 2008
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel GW711
Replace the water inlet valve. That will fix the problem. No need to replace anything else.
Mar 06, 2018 | Fisher and Paykel GWL11 Top Load Washer
When washer finishes cycle and spins out water will start dripping into the washer and will get the clothes wet if not taken out
You have a faulty water inlet valve which needs to be replaced. If it's cold water dripping into the machine then it's the cold water inlet valve.
Oct 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL11 Leaking water
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
Apr 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
On our Fisher and Paykel, the spin cycle does not
ok guest you can set a fisher and paykel machine to skip one rince cycle so as to save water,
Feb 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Leaking water
yes, that is a common problem with those. contact the company and they will help you out
Oct 25, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
140 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
