Question about RCA RP5430 Clock Radio
I got as a christmas present a RP5430 Clock/Radio, the time portion losses about 3 minutes every other week and the radio has very little reception and you really can't listen to it. What should I do, I do not have the receipt as it was a gift.
Something is wrong with it.
honestly, go buy the same model, and return yours in the new box defective a few days later.
Posted on Jul 26, 2008
SOURCE:
How do you set the alarm and clock?
Setting Clock
1. Slide the switch /WAKE1/WAKE2/
on the top of the unit to clock position.
2. Press REV or FWD to set the clock
time. The time decrements or increments
will follow by a faster rate when you press
and hold the buttons. The ":" between
hour and minute time flashes when you
are setting the time. AM or PM icon will
also beside the time.
3. Slide the switch /WAKE1/WAKE2/
on the top of the unit to position
when finished.
Setting Wake Time
This unit allows two wake times to be set.
on the top of the unit to WAKE 1 or
WAKE 2 position.
respective wake time. The time
decrements or increments will follow
by a faster rate when you press and
you are setting the time.
when finished.
http://audiovox2.info/docs/common/RP5430/RP5430_OM.pdf
Mar 15, 2011 | RCA RP5430 Clock Radio
How do i change the time
On the link below is the manual for the radio.
http://www.voxxsupport.com/images/manuals/RP5430/media/RP5430_UMEN.pdf
Good Luck and please rate 4 thumbs up for the free answer
Sep 07, 2010 | RCA RP5430 Clock Radio
RCA RP5430 clock radio transformer TIN HING U2812-093-045E specs
It is 9v and 4.25v, measured from a working transformer in the clock radio
Dec 17, 2009 | RCA RP5430 Clock Radio
Clock is flashing continuously and unable to set it.
Found the manual for this product here:
Looks like this clock has internal batteries that need replacing every 2-3 yrs.(See "auto-clock set" under "clock".
Hope this helps.
Dec 16, 2009 | RCA RP5430 Clock Radio
RCA atomic clock radio didn't reset to DST
Perhaps you've already tried this but on my atomic clock I have to select the DST option and make sure you're in the correct time zone.
Mar 09, 2009 | RCA RP5430 Clock Radio
Display is blank, radio/clock won't turn on.
call the costumer service for that they are always really nice and helpful!
Feb 10, 2009 | RCA RP5430 Clock Radio
Can't change clock to eastern standard time
Can't solve it but the clock doesn't know the government changed when daylight ends.
Nov 04, 2008 | RCA RP5430 Clock Radio
Need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Oct 27, 2008 | RCA RP5430 Clock Radio
RCA RP5430 Clock Radio Logo
59 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
