Question about Nikon Coolpix 7600 Digital Camera
Lens Error Message
I have had my camera for about a year, and it was working great. Then all of a sudden I am receiving "Lens Error" messages and the camera won't do anything until I turn it off.
  • 3 more comments
  • glyfa May 05, 2008
    Exactly the same problem, the camera wa sworking fine, and then without any reason it started saying that there is lens error.
    Since then I have no been able to use it.
    Any suggestions?
  • Anonymous May 12, 2008
    Same here, had the camera for 2 years and now I'm getting lens error. Must be a design fault. I can not even find my reciept to return it and I'm going away in a week on holiday and could really do with having it fixed or replaced.
  • Anonymous Jun 06, 2008
    the same problem.with lens error.. same with user Reezee.. what shoud do?
  • Nitin Nakti Oct 08, 2008
    I have also faced the same problem. I have purchased it just 1 year back. It was working well but suddenly it started showing lens error.
    Nitin
  • mrpoland Jan 08, 2009
    my zoom lense will not close when I shut the camera off. Also the Wide and tight angle button does not work. If you know how to fix this please send me an e mail at mrpoland@juno.com
I was getting a lens error message when turning on my camera and hence couldn't use it.
To fix it, when turning on the camera continue holding down the power button and then press the zoom in button (T on mine) and hold it. This forced the lens to stay zoomed and then it just started working again. Hope this helps!!!
Posted on Oct 18, 2009
Hi there
I had the same problem a year after I bought my camera. I returned it to Nikon and they fixed it and returned it. The problem reoccurred 3 times and each times Nikon repaired it free of charge. Then after a year it went again and, when I returned it to Nikon they sent me a new camera. Within a couple of months the new camera had the same problem. I have since resolved it with new batteries! The original coolpix rechargeable batteries do not seem to recharge properly so when I put ordinary AA batteries in it suddenly worked. Good luck.
Posted on Dec 24, 2008
My lens 28-75.Has worked fine for a year.
I have a lens like yours but mine ( I don't think) will fit a Pentax. I had the same problem. I thought it was the camera. So I took them both to the camera shop. When I was told that the lens was the problem I bought a new lens. I still have this one and if you find a fix for it I'd like to try it on mine.
May 11, 2010 | Tamron 28-75mm f/2.8 XR Di LD for Pentax
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
"Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Apr 19, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens error,restart camera
take your finger and slide it inside the lens and pull it out slightly, not all the way but enough that it moves. then hit the power button and it should work fine after that. good luck!
Nov 23, 2008 | Canon PowerShot SX100 IS Digital Camera
Lens Error 10e, 1,1,0
Well, the only time i received that message is when I was holding the lens down with a finger while turning it on.
Sep 14, 2008 | Kodak EasyShare M853 Digital Camera
Error message- remove lens cap and press > button
Is your lens not retracting?
I've got the same problem and with the lens not retracting - this is why i get the message.
Jul 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Nikon Coolpix 7600 Digital Camera Logo
352 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
