Question about Whirlpool LHW0050PQ Front Load Washer
Not spinning at all
My whirlpool won't go through the spin so therefore never gets to 'done'. I've tried using just the spin cycle and it won't do that either. I did unplug and plug it back in and that didn't help either. The satus lights are on spin and flashing and the start button is flashing. the tub moves freely when you push it by hand. Tonight I'll have my husband remove the top and make sure everything looks ok.
  • 1 more comment
  • Anonymous May 23, 2008
    mine wont do anything anymore the start button flashes and if i push it it only washes for about 3 minutes. If I select rinse or spin it doesnt do anything . the light for was is always lit.
  • newfdogs Jun 02, 2008
    EXACTLY the same problem as 1serious1.
    I've checked the filter...it's clean.
    I've checked the drain hose...it's clean.
    I've checked the belt tension...it's good.
    Drain motor runs fine. Drum turns freely.
    Any advise would be appreciated!!
  • waudlob Aug 04, 2008
    I'm having the exact same problem?
  • 60 Answers
Your washer needs a new speed control board located in the bottom right corner of the machine it controls everything to do with the motor
Posted on Aug 04, 2008
My whirlpool cabrio washer has started shutting off half way through the wash cycle...won't drain and spin...could the motor be overheating or is there something else I can check?
Most likely the cycle timer needs to be replaced. it is basically a clockwork device that that has cogs attached to a spindle. if you check the schematics for your product you will find the part no. etc. any servicing of course needs to be done wit the power disconected
Jan 20, 2013 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool cabrio wtw5600xw0 will not spin
I had the power button off so no lights were lit. I also tried it in teh done mode. None of the buttons put it into self test.
My issue with spinning is it will not complete the spin cycle and the lid lock light flashes leaving water in the tub. If I out the machine on drin and spin it will remove most of the water
I also tried the soil level temp keydance to check the console self test and it would not go into that mode either.
Honda Parts.
May 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Why won't my whirlpool model #LSR8233JQ0 go through the rinse cycle or the spin cycle
i have no info on this model, but if its a front loader then you will be looking at your drain pump motor as at the start of the rinse and spin cycles it will need to drain if it cannot it will not even attempt to continue on, so take that little drain pump cover off and have a look inside the propeller it may just be jammed up, if not it may be blocked somewhere along the hose or just a faulty pump altogether, if its a top loader you will be looking for the same thing but if it isn't the pump it will be the lid switch that senses the lid has been shut as all whirlpool top loaders must be able to activate the lid switch or else it cant spin (simply a safety feature to prevent injury), get back to me if you have any questions
Nov 21, 2011 | Whirlpool Washing Machines
After wash cycle, tube will not drain water?
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Whirlpool Washing Machines
Whirlpool LHW0050PQ Front Load Washer Logo
177 people viewed this question
Dan Webster
Dan Webster
Sal De
