Question about Philips 32PF5320A 32 in. LCD Television
No sound only pic
The pic is there but there is no sound while changing the channels. But there is no problem when i hook up dvd through AV jacks? any solution?
What do you mean exactly when you say 'there is no sound while changing the channels.' is there sound when you turn it to a channel and leave it there???
Posted on Mar 31, 2008
6ya staff
SOURCE:
Finding the AV Channel on a TV
There may not be one on your TV. If your TV has audio and video input jacks then keep changing channels going from high channels to lower ones. When you get to Channel 2 then the next one down should be AV. If your TV doesn't have the A/V input jacks, then you'll need a modulator. This will take the audio and video outputs of the DVD player and put them on TV channel 3 or 4 and insert it into the antenna connection of the tv.
Jan 23, 2014 | Televison & Video
I have hooked up a dvd player (with red, yellow, white output wires) to my ge tv model #25GT534 and turned the tv to channel 91, which is the av input channel. I get sound, but no picture. What am I...
check to see if the yellow rca jack is connected to the video out of the dvd player. If that does work try a different cord. You could try one of the audio(red,white) in the yellow section of both tv and dvd, to see if the yellow one is defective
Jul 20, 2011 | Televison & Video
Can you hook up a DVD player to this TV? It is a DTQ 13V5FC purchased in 2003.
I took a look at the specs for this set, and it has both front- and rear-panel audio and video input jacks. There's a button marked "VIDEO" on the remote that switches to the AV input so you can watch what you have connected. So yes, you can hook up a DVD player, but there are some limitations.
This isn't a stereo TV, so you'll need a Y-adapter (like this one from Radio Shack) to combine the right and left channel sound from the DVD player into a single mono input for the TV. This means you'll lose any stereo effects from the DVD. Also, even though there are two sets of AV input jacks, the TV can only use one at a time. You can't select the front or rear input separately.
Hope this helps. Thanks for using Fixya!
Mar 26, 2011 | Daewoo DTQ-13V1FC TV
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
My PS3 does not show a picture wene it is hooked up with AV cables it just has sound but wene I plug in a HDMI cable sound and picture works. How can I switch it back to AV cables? I know there is a...
YES,ON YOUR TV GO TO CHANNEL 0 THEN DOWN ONCE AV CABLES ARE HOOKED UP,SOMETIMES ITSCH.69 JUST KEEP TRIN AND IT WILL POP UP,MAKE SURE RED,YELLOW,WHITE ARE IN RIGHT HOLES ...RED IS PIC. WH.SOUND
Jul 15, 2009 | Sony Playstation 3 (PS3) Console
Can't receive pic and sound with the converter box.
The tv should be on channel 3. Otherwise, you can go to menu on tv, then find "autoprogram" and it will search all available channels. Usually tv should be on channel 3 if hooked up with a coaxil cable and aux or AV or Input if you are using rca jacks.
Jul 08, 2009 | Televison & Video
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
DVD is playing in black and white
check the norm pal or ntsc,or video format
Feb 17, 2009 | Pioneer DV-333 DVD Player
Problems hooking it to the television
The colored jacks match up to the jacks on tv. Tv must be turned to AV channel, Or input channel. The ports they are plugged into should have a channel printed by them.
If you are hooking it up through a VCR it is the same. Whatever it is hooked up to has to be on the right channel.
Channels are usually: AV or Input
Jan 18, 2009 | GoVideo DV2140 DVD Player/VCR
Wharfdale DVDRHD400 dvd recorder with 80gb hard drive
Sounds like if you are getting the right Video and not audio then the audio are hooked in wrong. Unless you are on SAP (Second audio program) in this case take it off of Sap. If you are getting the sound that you are looking at once you change channels to view another program, then it should be easy. Just change audio jacks back to AV1, 2, 3 etc depending on which one you are using. Hope this helps!
Dec 03, 2007 | Wharfedale DVD-M3 DVD Player
Philips 32PF5320A 32 in. LCD Television Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
