Question about Garmin StreetPilot c340 GPS Receiver
USB port defective
GPS USB Port overloads PC or Laptop USB ports.
    Scholar:
  • 52 Answers
Have you tried another USB cable? As long as it's got the same mini-USB connector, they are universal. Most digital cameras use these same cables, as well as many MP3 players and other handheld electronics devices.
If this doesn't fix it, most likely, it's a defective USB interface chip in the unit... and will need to be serviced. GARMIN 1-800-800-1020 (USA).
Fortunately, the USB ports on PC's are protected. When an overload is detected (> 500mA), the USB controller shuts down the offending port. This port can then be restored manually through the USB disgnostics, or simply shutting the PC down, and restarting it.
Posted on May 04, 2008
Why do you replace battery in gps my gps keeps shutting even with car charrger plugged in
Even with a dead battery....even with a battery removed, the unit should still operate normally when connected to an external power source, like a DC car charger. Common problem with the Nuvi 1100, 1200, 1300 & 1400 series is a loose USB port. If the port has broken away from the PC board, you will not be able to charge the internal battery and the unit will give you constant pop up notices that it is powering down or it may not come on at all. We've repaired hundreds of these units with defective USB ports. Please see this link for more info:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
May 24, 2014 | Garmin nuvi 1200 Car GPS Receiver
Have my nano plugged into USB port and mouse is turned on but still unable to use.
did you try in other PC or Laptop?
USB mouse has its own driver.. it takes time to load its driver automatically..
Check if its automatically installed driver.. or manually...
is your USB port in Good Look? if not .. port defect. if it is good.. your mouse is defect eaither wire or mouse itself..
Aug 19, 2011 | Computers & Internet
Trying to add on a wd passport hd thru usb port...plugged in on both ends, and drive sitting there making a clicking noise
sounds like the drive went bad have also try a different usb port make sure you are using one directly connected to the laptop/pc not thru a usb hub
Mar 27, 2011 | Western Digital My Passport Essential 320...
Why can't my PC detect Garmin 255W when I plug it via USB?
First makre sure that the usb is working. Just plug anythign into the usb port and if it detect it we know that is working.
Now with the GPS plug the usb cable into the port you tested then plug the gps on the other end. Watch your screen (PC) and see if it detects the gps. It should say one of two things. One will be device discovered Garmin GPS (something along that line) or it may show USB storage device. You can plug it in and look under my computer for these if you missed what it said. Some versions of windows are better than others at detecting whats connected. And some hardware is better than other at detecting something on a connected usb cable.
You should also plug the cable into a differant port if you had left it connected and were getting this problem. And you should try plugging both into a differant computer if you can. Doing these can tell you if the problem is the gps, the cable the port or the computer itself. Usually just changing the port is all it takes.
Apr 03, 2010 | Garmin nuvi 255W GPS Receiver
Unit goes into computer mode when I plug in the car charger lead. I go through the 'loading maps' screen, then the PIN screen, and it defaults to computer mode and I can't get any maps to show.
The rear mini-USB port is defective, making the unit think its connected to a PC. The port needs to be resoldered or replaced. Please see this link:
See the section about the PC icon.
http://www.sharc.net/gps_charger_repair.htm
- Jim
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
Trying to connect from USB laptop to parallel printer
You can't have a double hook up to it,When the parallel port is used the usb port is disabled and when you use the usb port the parallel port is disable.This is done to prevent damage to the printer.You can network the laptop with the pc and print that way though
Jun 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
An error message stating that the device overloaded the usb port appears (yellow light at the port).
Go to the device manager and uninstall all usb devices. Turn off computer, unplug all usb, reboot twice, plug usb in again. Also helpful are troubleshooting usb articles here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 21, 2009 | HP PhotoSmart 7960 InkJet Printer
Magellan explorist 600 gps with windows xp
It is more than likely a defective USB cable. I am on my third cable. They don't stand up to the abuse.
Apr 03, 2008 | Magellan eXplorist 600 GPS Receiver
Usb port trouble
You may have to run the program with administratve rights. (I had some trouble after getting a new laptop with Vista, that fixed it).
It may also be a faulty port on your gps, or a breakage in the usb cable... Or it may be broken...
Dec 15, 2007 | Garmin eTrex GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
400 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
