Dvd player makes humming sound while playing disc's
A dvd fell off of the tray inside player and got it stuck so i took the cover off and removed the stuck dvd. all the mechanics seemed to be working so i put the cover back on and played a dvd. The video seems normal but there is now a buzz that varies in volume according to what is playing and what is the primary color on the screen. (red seems to make it the loudest.)
  • 2,326 Answers
I would suggest to check your connections at the back of your DVD player, a loose ground connection will cause the noise.
Try with a different cables and TV as well, just to isolate the problem.
Posted on Mar 31, 2008
  • 790 Answers
Hello ray sanders ,
But still the dvd plays right ??
  • Kanth raj
    Kanth raj Mar 31, 2008
    You gotta give it to the service to manually open it and repair it for u ... the lens reader alignment will be distorted...
How do I remove a stuck DVD?
It sounds like your problem isn't the dvd is stuck, since it seems to be spinning up, it sounds more like your ejection system has stopped working for some reason.
To fix either you are going to have to remove the outside case of the dvd player and expose the internal chassis. There are anywhere from 4 to 8 screws holding it on on the bottom and back of the unit, Make sure the dvd player is unplugged before you remove the cover.
Once you have the cover off, if the dvd is simply stuck, you should be able to see what the issue is; is it misaligned in the housing was it inserted incorrectly, are there in fact 2 dvds in the player, etc, etc. Gently remove the dvd and replace the case and enjoy.
If you can't see any reason for it to be stuck it may be the ejection system. The eject system will have a belt and sprocket system to move the tray or push out the dvd depending on the player. Make sure the belt is on the wheels correctly and that the sprockets mesh properly. If you can't see anything wrong try testing the ejection system with the case off.
Make sure you don't have any objects in or touching the dvd player, you don't want to short out any of the components if a screw fell into the dvd player onto the mother board, etc. Plug the dvd player back in, make sure you don't touch the inside and try to eject the dvd. Watch the ejection system and you should be able to figure out what is going wrong. Once you have figured it out unplug the unit and put the items back together. If you can see that something is broken then you will have to determine if you can have it fixed or if it wouldn't be cheaper to simply ditch that unit and purchase a new one.
Hope this helps.
Oct 12, 2015 | Televison & Video
DVD player makes grinding sound and doors don't open
You may have a stuck DVD in the player. Most DVD players have a small pin type hole in the front where you can inser a paper clip to manually open the tray. Otherwise, you have to remove the cover of the drive to actually see what is happening. support hp com Maybe this link will be of some assistance.
Mar 01, 2015 | Televison & Video
When I turn on my Sony DVP-SR200P DVD player and press the eject button it's turns the DVD player off.
turn on first the dvd player and wait to read a disc inside if no disc inside the tray it will say disc error. if the unit doesn't turn off, eject now the the cd tray. if get turn off, remove the cover then check for an stuck up gear or obstruction in the cd tray assembly. you can check also the power supply board which may have unusual parts like bulged or burnt component parts.
Oct 06, 2012 | Televison & Video
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
The disc is stuck up in dvd player how can i open it up to remove the disc thanks
Remove DVD player from the mains. Look for the slotted opening covered with plastic cover at the bottom front, which can be opened easily by hand without much force. After opening it put a small flat screwdriver (locate the stud inside) & move it so that the tray will just open. Then pull the tray & remove your CD.
Aug 13, 2011 | Philips DVP3982 DVD Player
DVD tray is stuck. No DVD inside. I've removed top cover and there is no obvious mechanical obstruction. I can hear the motor attempting to move the tray but there is no movement of the tray or other...
Helo tom,
According to your problem description, it seems to be the problem with the DVD door mechanism. To fix the issue door mechanism, you have to replace entire mechanism think it helps! Let me know.
Best Regards,
Chandrashekhar Bhat
Dec 25, 2010 | GoVideo DV2130R DVD Player / VCR Combo
Dvd stuck in machine will not play or open to remove movie
there might be something hooking the disc tray that is prevent it from opening.
The solution to this problem now is to, get a screw driver, unscrew the screws on the player, open the player cover so that you can gain access to the disc stuck inside, remove the disc and check for what's preventing the player from ejecting.
Take care.
May 30, 2010 | Panasonic DVD-S35 DVD Player
Sony DVP-NC600 Powers down during CD playback
The tray won't open. I took top off and dvd top side holder, but the laser mechanism won't disengage so the tray will open, even with no dvd in it. How do
I reset it. I power on, hit open key, it makes hum noise then goes by to
standby mode.
Jan 06, 2008 | Sony DVP-NC600 Multi-disc DVD Player
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Not closing
Hello, with mechanical problems with sophisticated systems of gears etc, the only way thate one can fix it is if you send me a digital picture yourself. To access the inside of the DVD player, you will have to get a handyman to open the DVD player up with a screwdriver, by undoing some screws which hold the cover to the player itself. Then, with the player's circuit boards (The Green/brown Boards with weird components on it) showing, take around 5-6 photo's of the loading tray and the playing tray.(Where the disc is when watching a movie)In the time being, open the layer's cover as instructed before, and look at the inside of the tray for any broken plastic, debris or anything stopping the tray from opening. Good luck!
Oct 05, 2007 | Sony DVP-NS305 DVD Player
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
Electro Med Services...
