AirDash USB stick problems finding the wireless signal from the router
Loading the AirDash USB stick and it won't work. Seems to find the signal from the wireless router, but won't connect to the internet. When we Scan for signals, comes up blank. We are using the TRENDnet wireless firewall router.
  • 349 Answers
You may need to go into the wireless router and turn the wireless option on,
if you have set up a security key, or one is set up automatically you need to put that key into the software of the Airdash USB stick setup,
good luck
Posted on Apr 01, 2008
I have several computers in my house, and just purchased a Netgear N600 High Performance Router. All computers easily pickup the signal and connect to the new router. However, one of my computers using a...
you might try moving your computer closer to your router
make sure your routers and your dell 1450 settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet if applicable
hope this helps
Jan 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
ADAPTER not working
Check the distance bet computer and the Router.
Donot keep your router near television, microwaveoven or any radio active devces, it may reduce the performance.
Check the Antena terminals for any loose connections.
If possible check your wireless signal strength with another Laptop, to diagnose the router is working fine.
If everything seems to be fine, it maybe the issue with the Adapter.
Goog Luck
Feb 12, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Bad Signal
Try connecting to a different router, at a Starbucks or other "free wi-fi" location. If you get more "bars", your iPod Touch is NOT the problem.
Access the web-interface on the router, and ensure that the router is set to maximum-power of its wireless signal-strength.
Get a friend to copy the CD onto a USB memory-stick,
and install the software from the memory-stick.
Dec 27, 2009 | Belkin F5D7234-4 Router
I'am not a strong signal from d-link wireless router
Move closer to the router and if you can open up the settings of the router and make sure the output power is set on 100%
the issue could also be a poor antenna on your computer, usb wireless adapter sticks generally have poor signal due to a very poor or no antenna at all.
Sep 12, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
USB suddenly can't find router
More information about your problem is needed. Restore settings to default, uninstall drivers for usb adapter, reinstall.
Apr 20, 2009 | Linksys Wireless-G WRT54G Router
Wireless program..
Yepp, you can use your Toshiba 1405 with a wireless router. What you need is an wireless USB-stick to connect to the router. And you need drivers to that stick, but they follow with the stick when you buy one. You dont need any other programs, the settings you do in XP network.
You will find wirelessUSB-sticks and wireless router (sometimes a sticks follows with the router) in any internet shop or in any pc-shop near you.
Here is an example, its a D-link wireless router and a wireless usb-stick
Good luck
Mar 24, 2009 | Toshiba Satellite 1405-S151 Notebook
Wireless router signal
I suggest that you move the router around to find the strongest signal for you computer or if your computer has a small antennae try moving that fround for the best signal
Lou Margolis
Allied Electronics
Aug 14, 2008 | NetGear WGR614 Wireless Router
Change of encryption key
Connect a cable from the router LAN port to the ethernet port on the system.
Check whether the internet is working.If yes
Click on start RUN & type in cmd
Then type in the dos windows the following command ipconfig.
Look for the IP address something like 192.168.x.x or internet explorer & type the IP address from the above step in the address bar without the http or www . it will open the router GUI .It can ask you for the username & password depending upon the router model.Please let me know.It could be anything .try some of these.admin blank,blank means leaving it blank,or blank admin,or admin password ,If it opens try finding the wireless settings(advanced)Look for key 1 : That will be the key which you need to put in .Let me know if it works.All d best
Jun 01, 2008 | Ashton Digital (WRCB-1011R) Wireless...
Wireles conection problem
I've run into this issue with USB wireless network cards from DLink, Linksys, and Netgear. For me, the issue was with the USB ports on the PC and not having enough power for the device, the connection would stay live for a random amount of time and then all of a sudden it would die (same thing would happen when resuming from hibernation or standby). I added a PCI card with a powered USB hub in it and it solved my problem.
Hope this info helps!
Jan 15, 2008 | D-Link DI 514 Wireless Router (DI-514)
Wireless connection keeps falling
It may be just a problem of the signal bouncing around and your laptop is struggling at times to find the signal. Some earlier laptops don't have a wireless booster built in the screen. Go to your laptops' web site and see if there are any updated drivers for your wireless card. If still unhappy with results purchase a USB wireless dongle and dissable wireless card, it may have a better reception area, or purchase a signal booster that works in conjunction with your wireless router.
Dec 18, 2006 | Edimax BR-6114Wg Router (BR6114WG)
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
