Question about Insignia D300a PC Desktop
DVD Burner installation
I have an Insignia D300. I just bought a Samsung DVD Burner which I'd like to install. The computer I have has an A Drive. Can you walk me through the installation process?
Thanks
    Problem Solver:
  • 7 Answers
Alemap66,
There's a great video on YouTube:
http://www.youtube.com/watch?v=1qh6av2UviA
I hope this helps!
I use a Samsung DVD burner also. Great drive.
Posted on Apr 01, 2008
6ya staff
SOURCE:
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
LG GH24LS50 DVD-ROM Drive Plays Only CDs, Not DVDs...
Since you bought this used unit at a thrift store, it is entirely possible that it is defective.
Jul 24, 2017 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
I'm trying to install a PC-DVD Game to my LG CD-ROM CRD-8521B, It plays CD's but wont play DVD's of any sort. Really need help...
The CD rom is limited to CD's. In order to read a DVD, you will need to install a DVD rom. My suggestion is to get an external DVD Burner - i just bought a Samsung slim external DVD burner that reads / writes CD's and DVD's.
You will have no luck ever reading a dvd in a cd rom.
May 19, 2010 | LG CRD 8521B Internal 52x CD-ROM Drive
Does not recognize DVDs, computer
I would like to suggest that you attempt to download & install the codecs that your media player requires, before it will play a DVD.
I found this typical when I was using the Vista operating system with Windows Media Player 11.
The codecs can be found as freeware online & a good site for the apt codecs for WMP 11 is @ www.majorgeeks.com once you are on the site, click multimedia on the left of the page, then scroll down to the codecs required.
The K-Lite series of codecs seem to work well with WMP 11 on Vista.
I truly hope that this has resolved your problem, as there is nothing better than watching a fine movie on the old PC.
Failing my advice, you could always 'Rip' the said movie to your media player & view it from your hard drive.
Good luck anyway.
Warmest regards,
Ste
Apr 18, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Trying to install a Sony CRX300a DVD
Yes do that is a great idea. DL & copy to a flash drive, then run software from drive.
Feb 06, 2010 | Sony CRX300A (CRX300E1BLACK) CD-RW/DVD-ROM...
Samsung SH-S202N CD DVD burner
I have the same Samsung Multi DVD Recorder as it calls itself and it works OK with XP for me. You probably need to install the Nero software that came with it as it normally contain the hardware drivers that are needed. Sorry if I'm too late with this reply but I only just came across your post.
Feb 19, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
Roxio 8.0
You did not state either  the type of computer or the type of cd/dvd drive. It could be either an IDE-ATA or and S-ATA, so I am going to guess that you are removing the old CD on a PC and installing the new cd/DVD. If an IDE-ATA (That is the one with a whole lot of pins that a ribbon cable attaches too) thge look on the back to make sure that it is either set to cable select or Master. After hooking the wires and screws ,just like the old CD had attached,close the case and start the computer.  At this point it would act exactly like a CD burner. You must install DVD burner software not to use it as a DVD player /burner. Install your ROXIO and  you should be ready to go.  If I missed anything or misunderstood just let me know. Good luck.
Dec 17, 2008 | Roxio Easy CD & DVD Burning
Samsung SH-S182 DVD±RW Dual
If the drive is "Master" (the first drive in cable line installed) then the jumper goes to "MA", if it is a "SLAVE" connected drive then the jumper goes to "SL".
May 06, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
DVD-RW Name Changes When Blank DVD Inserted
p3, Did you try burning the DVD and it failed? You should try upgrading the firmware on DVD drive. http://www.samsung.com/support/productsupport/download/Model_Select.aspx?type=ODD+Products&typecode=300400&subtype=DVD+Writer&subtypecode=300405&model=TS-H552U&filetype=FM&language= Or, your just interested why Windows is calling your expensive DVD burner a measley CD Drive? Your Burner is an all-in-one.(I think) It plays(and burns) cd's and dvd's. Whatever program you use to burn has not informed Windows of its true intentions yet...Which is to burn a dvd or a cd. It doesn't know what you are burning until something tells it to. Let me know what happens. Good Luck, Tim
Mar 06, 2007 | Samsung 16x (TS-H552U/BEWN) DUAL LAYER...
Insignia D300a PC Desktop Logo
73 people viewed this question
Top Insignia Computers & Internet Experts
Ekse
Joaquim Martins
John Waters
John Waters
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
