Question about Onkyo TX-SR605 Receiver
True HD - biggest secret
Can anyone help.
I've just connected (via HDMI) the new Panasonic Blu Ray BD30 player. All's fine and fantastic but I'm struggling to get True HD to work. The trails and menu pages have sound (Dolby Digital) but once the movie starts the sound mutes and Dolby True HD flashes on the display as though this had been muted. I really want to hear the great True HD but simply can't get it play on my amp. Any advice and what doos the flashing display mean? Oh and trust me I hadn't muted the amp accidentally.
  • Blu Ray Man Apr 01, 2008
    It is a True HD disc yes - "Cars" which came free with the machine. Any other suggestions?
  • 97 Answers
Are you playing a TrueHD format disc? Just like DTS 5.1 or any other format if your disc isnt coded in TRUEHD then your not going to get it. DTS or other formats cannot be "converted" to TrueHD like the video portion of a standard def disc. At this point there arent alot of TrueHD discs out but be paitent, this may change. Or not, due to the fact there are other "lossless" formats that may be more widely adopted. Sort of like DTS and THX were when DVD first came out. Hope this helps.
Posted on Mar 31, 2008
SOURCE:
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
For a blu-ray player model #DMP-BD30, how do we get updates
goto http://panasonic.jp/support/global/cs/bd/download/bd30/index.html
download this and put it on cd-r using a program like nero or whatever burning software your computer came with, then put the disc in the blu ray player, turn it off then back on and make sure it doesn't get interuppted
Sep 08, 2009 | Panasonic DMP-BD30K Blu-Ray Player
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
MY PANASONIC BD30 BLU-RAY PLAYER WILL NOT PLAY ANY BLU-RAY DISCS IT WILL PLAY DVD'S AND CD'S
i bought new panasonic bd player bd30. thugh amazon (us). it is not at all reading any disc. i brought to india ithout box. i am using 220v to 110v converter. here it is loading but not reading any bd disc nor region 1 dvds , please help me to solve the problem. it is also new one. rajkumar ( [email protected])
Jul 19, 2008 | Televison & Video
Panasonic blu ray player ?
Hi , i just purchased a blue ray dmp bd30. i wish to use it as to play cds. It is connected to my 2 channel amplifier from the audio outlets, it is connected through the HDMI connection to a Pioneer PDP-428XDA. is it possible to play cds with the plasma turned off? I have folowed the instructions which describes turning off power from the options menu, but the options menu doest display?
Jul 01, 2008 | Panasonic DMP-BD30K Blu-Ray Player
Onkyo TX-SR605 7.1 Channels... Problem
firmware up date go to onkyo homepage
Apr 01, 2008 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
156 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
