Question about Simplicity Quilter's Classic SW240 Mechanical Sewing Machine
Wind disable I am just getting started with my sewing machine and before I sew it is giving me a wind disable error message. I tried to follow the directions in the manual to thread it but it won't start sewing. Do you have any suggestions for me? Thanks for your help, Tammy
SOURCE: Needle doesnt hook bobbin thread while sewing
Our machine had the same problem, there was a piece of broken thread stuck in the upper tension spring keeping the tension spring open. removing the broken thread in the upper tension solved the problem for us
Posted on Mar 21, 2007
informatica
  • 1114 Answers
SOURCE: how to i thread it
You can download the manual from the link below: http://www.simplicityhomecare.com/manuals/ There is a quick start guide & full manual. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 21, 2007
SOURCE: Baby Lock BL 3000 Sewing MAchine Manual
I am trying to find both the Service and User's Manuals for this machine. Is there anywhere these or either of them can be downloaded? Thanks in advance for your help!
Posted on Oct 30, 2008
  • 76 Answers
SOURCE: threading instruction for model #1220 simplicity
http://www.sewingstyle.com/Simplicity-Sewing-Manuals.htmlnot
not sure if you have the manual, try this site for a manual,
Posted on Sep 03, 2009
  • 5 Answers
SOURCE: How to properly thread the bobbin
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin. NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  3. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  4. Slide bobbin cover back into position.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Posted on Jul 29, 2010
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Wind bobbin frister rossman 420
Hi - if I understand your questions you're trying to wind a bobbin on the top, and haven't got as far as sewing yet.
To do this you usually have to put the bobbin on the top spool for it, and move that into position so that it turns.
To disengage the needle so it doesn't go up and down whilst you wind the bobbin up, on most machines you have part of the main drive wheel (on the far right) which turns against the rest of it, disengaging the part of the drive which powers the needle going up and down.
Or at least that's how it works on most machines.
Jan 28, 2013 | Sewing Machines
When i try to stitch it won't let me and instead says "wind disable", how do i fix it?
Wind disable means you're in the bobbin winding mode. The chrome shaft on the right end of the top of the machine is pushed to the right. Push the (bobbin winder) shaft to the left side of the slot and you should be able to sew again.
Jan 19, 2011 | White Sewing 2999 Mechanical Sewing...
We have a Touch & Sew 640 that we ARE trying to get running, and we need a manual, and specifically how do w thread the bobbin.
To wind the bobbin, select straight stitch, thread the machine up as normal making sure the presser foot is up, open the slide plate, push the little button over to raise the winder, take the thread and wind it round the presser foot screw a few times, press on the foot control slowly and the bobbin will wind, when you have enough, stop, close the slide plate to drop the winder down, pull the threads to the back and start sewing. for manuals try www.tandtrepair.com
Jun 24, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
What does error E1 mean on a brother CS6000i
hello,the E1 code simply means the machine is working so hard,you can follow the information below to help you fix the problem,
The instructions for bobbin winding tell you to click the start button for the bobbin to wind. When you do that you get that E1 with a beeping. What they don't explain is that in order to press that "UP" arrow button to get the bobbin to wind..........you need to UNPLUG the foot control. So, in other words it to be used for sewing w/o a foot pedal. Now instead of doing as per instructions, assuming you've plugged everything in (foot pedal), after winding is finished just press the foot pedal and your off and running or sewing as the case may be. BTW, look it up in the TROUBLESHOOTING SECTION OF YOUR MANUAL.
please kindly rate the solution if it;s helpful,
take care.
Jun 06, 2010 | Brother CS6000i Computerized Sewing...
Have a new singer7463 machine can i wind a bobbin on top without useing machine to sew also when useing machine to sew can i wind a spare bobbin
To learn how to wind the bobbin on top and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Sep 12, 2009 | Singer 7462 Mechanical Sewing Machine
Bobbin Winding message appears when machine is turned on
Is the bobbin winder holder clicked over to the right like you are trying to wind a bobbin? If so, and you are not trying to wind a new bobbin, click it over to the left.
Mar 09, 2009 | Kenmore 19233 Computerized Sewing Machine
Can't get Bobbin to wind properly
Verify that your thread path is correct when winding the bobbin. It has a distinctive path including a tensioner that helps your thread wind smoothly. Do not use a bobbin that is not wound smoothly because (as you already know) it could possibly break needles and damage the machine.
Brother CS 80 Sewing Machine Bobbin Rewind
Nov 09, 2017 | Kenmore 15208 Mechanical Sewing Machine
Simplicity Quilter's Classic SW240 Mechanical Sewing Machine Logo
169 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
