Laptop not connected to wireless network
      i use bsnl broadband with dataone wa3002g4 router. when i try to connect with wired coonnection it's ok but when i try to connect with wireless lan my pc shows but not coonected with router. i also try another
router like d links  & other to verify and it's solve my problem but i want to use bsnl dataone wa3002g4 router so please help me to solve this problem.
anup n.m.
  • 1,027 Answers
You may have to log into the router with a computer that is connected by cat5 cable using the ip address of the router, eg
make sure the radio is broadcasting.
on the wireless activity select your wireless from the detected
units, this will allow your wireless to function as the wireless will assign it an address.
Posted on Mar 31, 2008
Bsnl Broadband speed trick
1: One of the major problems with BSNL Dataone Broadband connection is the DNS servers they provide by default. Most of the timethey are very slow and sometimes they fail to respond. I noticed that Iam starting to spend a significant amount of time in DNS resolutionwith Dataone connection, often it is larger than the time it takes toactually get the reponse. Here is a simple solution to significantly speed up your DNS resolution.
Open up the network connectionprofile and
edit TCP/IP settings. In the DNS server address fields,specify the following
DNS server addresses: and208.67.220.220
Disconnect the connection and then connect again. You are done.
This specifies third party DNS servers which are significantly faster than BSNL Dataone’s DNS servers.
Tip 2: Firefox users can use FlashBlock extension to preventdownloading of Flash content by default, thereby significantly speedingup browsing experience. You can click on the placeholder icon todisplay the original Flash content any time. This is more of a passivetip in that reduces data usage to improve your overall experience.
Tip 3: You can try to increase your broadband bandwidth tweaking theTCP/IP parameters. The process is simplified by using TCPOptimizer, afree tool. It helped me, your mileage may vary.
on Dec 24, 2009 | Computers & Internet
Router and pc configuration to connect broadband via dsl modem
Sorry i tried to open and it could not display. what is the new IP
Aug 06, 2009 | D-Link AirPlus DI-524 Wireless Router
My dataone WA3002G4 (BSNL) modem is not connecting to internet
You need to configure the pppoe connection in the modem.
Jul 08, 2009 | Computers & Internet
This sounds like you need to set up your main gateway or WAN port settings on the datatone to match what your ISP provides? Is it possible to get suggested settings from the ISP?
Jul 08, 2009 | Linksys Wireless-G WRT54G Router
My dataone WA3002G4 (BSNL) WiFi router keeps resetting
Try to upgrade the firmware of the router.
Apr 21, 2009 | Computers & Internet
Network sharing
go into the TCP/IP protocol properties where we have option to obtain IP address automatically. have only one system with IP address and the remaining 3 systems select obtain IP address automatically. It will work.
Mar 09, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
How to activate wifi 802.11g;ADSL2+Router
switch on modem, computer. launch internet explorer. type in tool bar. You will get prompt for log in. log on id is admin, password is 0000. now, you will get connected to modem. On left side list, you will see "Wireless". Click on this. you will get to Modem wireless basic page. Tick "enable wireless",change country to India,click save/apply. Now open control panel on your laptop. You will be having wireless network tool / wizard. Click on this, follow the prompts to connect to the wireless network that gets detected automatically.
Nov 08, 2008 | D-Link DI 514 Wireless Router (DI-514)
How to configure paradign modem adsl2 6211-A3-304 in bridge mode for BSNL Dataone Broadband connection
I belive with this modem you will:
1.Access the interface, generally
2. Go to Advanced on the left.
3. Select WAN.
4. Now you may see several rows of info, look for the one that says PPPoE, and then click edit to the far right.
5. Select Next one time.
6. Here select "BRIDIGING".
7. Click next all the way to the end.
8. Reboot, after you clicked save of course.
This is how you bridge 98% of PPPoE providers with a similar paradign modem.
Of course the next device in line will have to provide your username and password for your DSL connection.
Hope this helps!
Feb 08, 2008 | Paradyne (6211-A2-200) Router
First login to your Router using default username and password
2. Click on WAN on the left side menu
3. You'll have options to add or remove configurations.
4. Please select and remove the bridge config as BSNL does not support Bridge.
5. Please click edit on the existing PPPoE Airtel Configuration
6. Set the VPI=0 and VCI=35 (for Airtel it would be 1,32) and click next
7. Select PPP over Ethernet (PPPoE) and encapsulation type: LLC/Snap Bridging and click next
8. Enter the following details:
PPP Username: Your bsnl username (no need to add
PPP Password: Your bsnl password
PPPoE Service Name: DataOne
Authentication Method: Select CHAP
Click Next
9. Check the Enable IGMP Multicast Option
Check Enable WAN Service Option
Enter the Service Name as Dataone
10. Click Next and Save. You should also save and reboot your modem.
If doing the above does not works, check if you have anything set Under TR-069 Client and remove all entries in this section however it may not allow you to save so you may just put the ACS URL as ( it won't accept this field to be blank so just enter any thing, I entered http://bsnl). Save and reboot the router. Should be online now.
let me know if anyone benefited from the above information -
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
425 people viewed this question
David Payne
David Payne
