Question about iLO (2 GB) MP3 Player
Infitek mp3 i conect to the computer with the usb,on and off,red ligh is on under one corne but he never take charge
I connect to the computer with usb but dose take charge but i only get to listen for about 5mins
Posted on Sep 17, 2008
  • 8,596 Answers
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
SOURCE:
How to charge My Mp3Player
Hi giannuandi,
Plug it into a USB port, and it should charge by itself. Use the USB cord Apple supplied for transferring data.
Dec 05, 2009 | Apple iPod shuffle MP3 Player
How to operate my infitek mp3/mp4
how you can upload music to your divice if you have i tunes and want them on your mp3/mp4 this device is not user friendly.
1. plug into your usb conection port
2. click on "my computer"
3. double click on "removable disk (F:). you should make a make a new folder for your music.
4. Open Itunes or what ever you use to listen to mp3's on your PC.
5. Drag song to "new folder" and any other songs you want to have
6. Drag your new folder into "Removable Disk (F:) window. which is your mp3/mp4
Jul 23, 2009 | Audio Players & Recorders
My mp3 doesnt connect into my usb it just disconnects and starts to charge can you help me
I assume from your description that either you are running a version of Windows older than XP/2000 or you need a special driver. Here is a link for the driver(s) you will need. Just enter your model number and select your version of Windows. Download and run the file and you should be up and running shortly.
May 30, 2009 | Samsung YP-U3 MP3 Player
My MP3 YP-U3 don´t power up
the battery might be dead. or u might have to take it apart and charge the battery by hand. ive done this before and it workd. i used a usb cord (5 Volts Max) wat ever u do do not charge the battery with anything over 5 volts. the battery inside the mp3 player is 3.7 volts, so be careful. It unplugs from the chip inside and the battery is easy to get out DO AT UR OWN RISK - PARTS ARE SMALL AND CAN BRAKE WHEN HANDLE CARELESSLY all u gotta do is find the seems on the sides and pull the player apart until it cracks open. then pull the connection tabs up for the usb and buttons from the chip, then by the hold button the chip will be guled to a ground, pull it apart and filp over the chip and u will see a lil clear plug with black (-) and red (+) wires on it, un plug it and set everything else aside, all u need is the battery. Now u need to find a old usb cord laying around and cut the end off that doesnt conect to the computer, splice the cord so that the wires are showing, cut them off EXCEPT FOR THE BLACK AND RED, now plug in the cord to a computer, or game console (ex. Xbox 360, Wii, PS2) then forcefuly slide the black wire onto the black (-) prong on the battery plug, same thing with the red one (+)
then let it set for 15 mins. now u have to conect everything back the way it was and snap the player back together and see if it will come on, if not you might have to take it back and get a new one if you have ur receat. i hope this works remember be very careful with the inside componets. Good Luck!
Jan 01, 2009 | Samsung YP-U3 MP3 Player
Infitek Player
not mac compatible
Aug 06, 2008 | iLO (2 GB) MP3 Player
Infitek shuffle ipod
Greetings bernince24,
Generally when an Ipod is charged, it is off and connected to a usb port with your computer. It simply draws power off the computer. It is all pretty intuitive, plug and play. Meaning the once you hook the ipod to whatever charging device you are using, it will charge on it own from there.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Apple iPod shuffle MP3 Player
Infitek mp4 player
First, check the user manual and see if proprietary video conversion software came with the installation CD. good luck if you lost the install CD, b/c Infitek's website sucks.
Either use Windows Media Player, ArcSoft Media converter, or another program to transfer video files to the player if it didn't come with proprietary software.
Jan 29, 2008 | iLO (2 GB) MP3 Player
How to charge my mp3
make sure the power IS ON , before you put the usb cord in..that is the only way to charge it,,
Nov 27, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Infitek mp4
E-mail only - no phone, no address:
http://www.infitek.com/default.aspx
Oct 28, 2007 | iLO (2 GB) MP3 Player
Infitek
Do you need program from pc to infitek to connect it or intstructions how to use it???
Oct 12, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
57 people viewed this question
Top iLO Audio Players & Recorders Experts
Ekse
Siul Oyaratgam
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
