Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Help with the green.
The TV worked fine one day and the next it had the red, blue, and green lines making the picture warped. I took off the front panel and adjusted as best I could and found that all the bulbs worked but only could adjust red and blue. I'm not sure what the problem really is since the green bulb works but can't be adjusted. I'm a noob at this but learn fast so any referance would be helpful.
  • 58 Answers
This is caused by failing convergence ic's. They take the image from the three picture tubes and align them so that one picture is displayed not three. They are the two large ic's on the biggest heat sink in the front of the tv, but changing them can be tricky b/c resistors feeding voltage to those chips may be bad to. It is a simple repair to a qualified technician but a major headache to a novice. It is economical to repair but I would leave it to the pro's. Hope this helped.
Posted on Apr 02, 2008
I have a projection tv that the pictures ghost and the red and green and blue do not line up on the screen. There is allso lines across the top of the screen and are red,blue,green. Looking at the screen...
You have a convergence problem. I have a tip which explains what this is, how to repair it and where to get the parts at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics . Let me know if this is not the problem or you need more assistance.
Thanks for using FixYa and for the generous rating.
hardrocko
Jun 13, 2010 | RCA HD52W59 HDTV Projection Television
Mitsubishi WS55859, was getting 2 and 2 blink, replaced the pico fuses and convergence chip - 3 times, each fix worked better than the next but evenually failed - now have it working, trying to adjust...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Red, Green, and Blue shadowed lights
the lense red blue green is warped you will need to replace those lenses
Aug 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Green screen with red and blue wavy lines
This is "NOT" meant as "expert" advice...as this is not my area...HOWEVER...I see no one has answered this yet...AND I got some good help from here a year or so ago that worked for me!
When I had a similar "green screen" problem with my SONY projection tv...the guy helped me by having me make "MINOR" adjustments to the red/blue/green etc knobs behind the panel. These were three small black plastic pieces and needed less than a 1/16 of an inch adjustment...try adjusting one at a time and giving it few seconds after each adjustment. It worked for me..at least for a while (till my wife gave it away to a friend because it was "too big"...ah! women!!! LOL)...hope this helps. (NON-expert help!)
Jan 11, 2009 | Televison & Video
Green Background with red wavy lines
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2009 | JVC AV-56WP74 56" Rear Projection...
MITS WS-65869 The green CRT is creating a warped image.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Dec 13, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
Visit the site linked here for more details. Repair of many popular brand devices are given. http://electronicshelponline.blogspot.com/
Mar 23, 2017 | Televison & Video
XBOX 360 - No display
Did somebody mess with the tv inputs?  Or Tv settings.  Make sure the green blue, red, cables are on good from the back of the tv set.
Oct 28, 2007 | Microsoft Xbox 360 Console
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
