Question about Fisher Paykel EcoSmart GWL15
Help please Premm!
Same problem I am seeing here. Washer will not pump out. GWL 15. Where do I find filter, and how do I access it? Do I need to go in through back of machine? Tip on it's face? Or should I just check hoses first? Any help is gratefully received! Thanks. Should I open pump to check? How do I go about that?
    President:
  • 1,294 Answers
Sorry for the delay. To locate filter see user's manual, if not...... It is the animal to which the thick hose comes down from the washtub, find out where you can have access to it. From this a hose goes to the pump. All these things are in the manual, if you hv it ie. "Plug off the wall first" If you can open up behind fine; so you get a good look at everything. Check the hoses after cleaning the filter & it still does not work. Most probably the filter is the prob. Hope this suffices for the time being, will check on your model, which is not too familiar with me. Info on washers is not too good, companies just want to sell...... Guys like us do something for the enviro.......all the best
Posted on Apr 03, 2008
Can I get to the drain pump or does the washer need to be torn apart? I cleaned out the drain plug- full of sand, filter clean, but I can't see the actual drain pump to see if something might be
Hi.
You can get to the drain filter without need for disassembling.The filter access is located behind the protective trim at the lower front side of the machine. Remove the trim and rotate the filter cap anticlockwise. Be prepared to collect the water that will flow through the filter. After cleaning the filter perform operations in reverse order to reassemble. Disconnect power before starting.
The pump is located at the bottom of the machine, behind the filter. Accessing the pump requires disassembling.
Diagrams for WM-2077 are available here.
Apr 21, 2012 | LG WM-2077C Front Load Washer
Gwl 15 washer no power. panel doe,s not ligthup and machine will not run. I checked elect. outlet. Outlet has power.
Hi just read your posting.There are 2 reasons why your machine does not power up.!st-- The drain pump is open circuit, and --2nd---your motor control is faulty.If you can look underneath the machine for me and see if you have the pump with a red or black fan.It will be towards the front of the machine and slightly to the right.Please reply with if you have this pump or another type and I can guide you throe testing the pump to find the exact part that is faulty
Jun 13, 2010 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Apr 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
POWER UNIT IS NOT WORKING
sounds like the motor controller is faulty.if u have power to unit and the lights aren't on then it is either faulty controller, or faulty pump or best case broken power wire.please turn power off b4 u work on it. dont want any accidents. please reply 4 more help.
Apr 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a bosch WFR 2460 washer. Er:15 error code.
You need to check and clean pump filter, normally located behind a removeable plastic cover at bottom front of washer right hand side.
If no filter found there remove rear panel of washer, and clean pump from rear of washer.
Please rate my solution.
Thanks.
Nov 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
My GWL 15 pumps so hard water comes out of the
A washer cannot pump the water out too fast, regardless of what you have done or have been told, the problem is too do do with the drain outlet, I suggest you completely take apart the stand pipe and any other pipes connected, and thouroughly clean them .
Thanks.
Jun 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Zanussi IZ 12 pump access
You should not need to remove anything to check and clean pump filter.
Open the filter door at the bottom right front of washer, there you will see the pump filter cover, unscrew the filter anti-clockwise, and remove the filter, and clean same.
With the filter out, you will see the filter housing, which is fastened directly on to the pump, have a good look inside the housing, and see if anything is stuck in there.
Refit filter, and test.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Zanussi IZ12 Front Load Washer
Washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 27, 2007 | Whirlpool GHW9150 Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
54 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
