My Fujitsu Siemens Scaleo P tower fails to boot up, sometimes shuts down after a few seconds, no output to monitor. Can you help
  • Isabella07 Apr 01, 2008
    Thanks for your help. No sign of any lights on the motherboard. Not sure of where the LEDs are, but there are definitely no lights illuminated inside the tower. All peripherals have been removed.
    On this occasion, all the fans are running and the lights on the front of the tower are illuminated. No beeps
  • Boeing1 Dec 19, 2008
    I have exactly the same problem fans working and case lights on with nothing displayed on the screen and no beeps when switched on. I have cheked the CPU fan which seems to be working quite fast although a little noisy would this be enough to cause problems. Several weeks ago I noticed that the CPU heat sink was clogged solid with dust and fluth because of the way the fan draws air directly down on to the heat sink could this be the route of the problem or is it still likely to be a fan or bios problem . Please let me know any clues would be most welcome .
  • 3 Answers
I also have a Fujitsu-Scaleo P, yesterday I had the same problem exactly as described here. The issue is that the CPU fan does not work anymore. It is easy to replace, only four Phillips screws to be removed. I simply don't know if the new fan replacement can be bought alone, or if the air duct will be in the replacement kit, along with the aluminum block. It is a Cooler Master Model made by Protechnic Electric model MGT 9212ZR-W25. If it wasn't that the problem, when the computer is still cold, try to boot it, press DEL which will bring up the BIOS Setup Menu, and you can see if the Fan still works: in one of its menus shows the Fan RPMs and CPU Core Temperature. Good luck.
Posted on May 04, 2008
    President:
  • 2,351 Answers
Hi Isabella07, your description sounds like a possible over heating issue. To confirm this, (while standing in front of the PC looking at the front of the PC case), please remove the case's left side panel. When you get the left side case panel off, start the PC & look at the CPU fan. (it's the largest fan mounted on an aluminum block with slits cut across it). Is the fan spinning? If yes, does it seem to be spinning slowly? When the PC started to shut down all by it's self, did you also start hearing high frequency beeps while the PC was running?
If you answer yes to any of these questions there ia a good chance the processor's fan is defective & needs to be replaced. On some models, the processor's fan can not be removed from the aluminum block & inorder to replace the CPU fan both items must be replaced. Replacing the CPU fan & heat sink should be done by a professional or by someone well versed with the internals of a working
computers. It is also unlikely for a PC to shut down because of a defective video card. So not getting display on your monitor (though you could have a problem with the graphics card), is not the reason your PC shuts down.
Does this look like your PC. (click the link).
http://www.phoenix-bmr.co.uk/Pic_M_Scaleo-P_official.htm
Posted on Mar 31, 2008
    Sergeant:
  • 201 Answers
My initial impression is that your motherboard or power supply is shot. Open your tower and check to see if the motherboard light is on and what colour it is, and if it is blinking and in what pattern. Also check the capacitors (little battery looking things) to see if the flat top of any has become rounded or peaked. This would indicate a problem with the board. Also if you have added anything new to the pc, try removing it and see if that helps to solve the start up problem. Keep me posted. Good Luck
  • 4 Answers
An friend of mine has the same problem with his Scaleo P pc, at first i thought it was the graphics-card, because everything else seems to work, but i still don't get anything on the screen.
I have taking everything out the slots and also took out the memmorys 1 by 1, still nothing.
Cpu dead or mainboard is fried.
Posted on Sep 09, 2010
How to remove the side panel from a Fujitsu-Siemens Scaleo Home PC?
Need the model number Chiara. Look on the back near the Windows product key, or up on the side of the computer tower. There are MANY versions of the Scaleo model series, and also case designs. Post back in a Comment. (Clarification and Comment options not available, at the moment. So I'll use a Solution box for that, and a Comment box for a Solution, lol!)
Nov 28, 2012 | Computers & Internet
My fujitsu scaleo p tower won't display anything on the monitor! The monitor works fine with other devices.... everything spins and all LEDs light up just no output to the monitor :/ any...
Have you tried putting the Graphics card in a Different slot? If you have and it is still not working most-likely it means that your video card has gone bad and needs replacing.
Jul 11, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Why wont my computor shut down ? If I shut it down it suts down and after about 5 seconds it restarts
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
Feb 23, 2011 | Fujitsu Siemens SCALEO 700x...
I can't find a driver for my grafique cart of siemens fujitsu scaleo 600 thank's for help :)
on this page
http://ts.fujitsu.com/support/downloads.html
type scaleo 600 for searh
you will be redirected to drivers download page
Feb 22, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
No sound on my pc!
step 1: check with the speakers on another computer to ensure the speakers are working fine.
1. Insert the CD-ROM titled 'Fujitsu Technology Solutions Drivers & Utilities CD' that came with the computer into the DVD tray and close it.
2. The Drivers & Utilities CD will start automatically.
3. Click on 'Driver Installation' option.
4. Click on INSTALL.
5. After the installation process the computer will automatically re-start. If not, for safety reasons (to not misinform/corrupt the information on the registry) restart the machine manually (Start Menu - Shut Down).
If you receive a message saying 'Found New Hardware Wizard' during the Drivers installation (Automatic recommended), ignore it and leave the Drivers & Utility CD to finish the installation. The D+U Setup is will detect the computer's hardware (it will not detect the drivers of any external devices you may have) and install the drivers needed. After you re-boot the machine you may get the Found New Hardware Wizard again, this will be your Monitor being detected, follow the on-screen instructions to install it properly (if you have a driver's disk, provided with your monitor or any other external device that you have connected, use this when prompted)
Jul 01, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
My Fujitsu Siemens Scaleo P tower fails to boot up, sometimes shuts down after a few seconds, no output to monitor. Can you help My computer works fine untill one morning it shut down with no warning....
pop the CPU, take a closer look athe chip and the socket, make sure there is nothing can create a short of creating any kind of heat. if you don't find anything there, I suggest a new CPU in order.
Apr 17, 2009 | Fujitsu Siemens Computers & Internet
Fujitsu-Siemens computer problem
Check power options...How to:- go to control panel and type power in the right hand box ie search control panel then change power options...
Oct 31, 2017 | Fujitsu Siemens SCALEO C772 17" CRT...
Onboard Sound Drivers and Video Controllers
Hi EsteG, found all your drivers for your SCALEO 800, these are also used for the SCALEO 800Si 2410 Silent+. They call it the 800 series, for XP. Click the link below.
http://support.fujitsu-siemens.com/com/support/downloads.html
Because it's the whole 800 series you'll need your manual to pick the correct Audio driver as noted in your manual. To narrow down the ammount of drivers in each area. There should be a sticker on the PC that has the serial No# . Enter that number on this link below. (Siemens Fujitsu) does not make this easy.
If I can be of more service, just ask.
Good Luck & Kind Regards.
Mike
Mar 25, 2008 | Siemens Fujitsu SCALEO 800Si 2410 Silent+...
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
5,831 people viewed this question
David Payne
David Payne
