Question about Asko W6021 Front Load Washer
Asko w6021 still not working
Greendude, I replaced the pressure switch on the washer this did nothing, I then had a service person come out and they talked to asko technical support who said a washer which was draining wtih the door open was due to a bad circuit board. The tech replaced the board and the the washer statrted to work and filled with water. It did not proceed from there. Once again the cycles could be advanced manually by pressing the start stop button and manually moving to the next cycle. Once we got tto position 10 spinn the washer would spin then drain and continue to drain and is right back where we were before . Anymore ideas would be appreciated
    Sergeant:
  • 351 Answers
Check that all the plugs are in the correct position on the board,you may have introduced the fault,because the only fault you had to start with was worn carbons.did you break off any links maybe J4 etc if the original board had the link taken off and you dont do it on the new board you will hard program the new board and will have to order another board. is the machine heating.put on wool wash and select heating you should hear it start to heat.let me know.thanks Ian
Posted on Apr 01, 2008
6ya staff
SOURCE:
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Mar 09, 2009 | Asko W6021 Front Load Washer
Asko W6021 won't start
change the carbons theres nothing wrong with the board
Jul 30, 2008 | Asko W6021 Front Load Washer
Follow up to asko w6021
try replacing the pressure switch i have had this fault before.the rear sensor supplies the correct water level,the front switch controls the heating and spin cycle.keep me posted.Iwork for asko i will speak to tech support on monday and let you know thanks.
Mar 29, 2008 | Asko W6021 Front Load Washer
Asko w 6021 still having issues
does it keep draining on any cycle and with the door open if so have you done anything with the pressure switch or the pressure sensor(red and black) it sits behind the pressure switch you may have to replace them.also check the board for any burn marks,i think you said you replaced it last time?if you have pressed down on the top of the pressure sensor you will have to replace it.am able to give you my mobile no or not.not sure how this site works.Ian
Mar 27, 2008 | Asko W6021 Front Load Washer
Asko w6021 washer not working
replace the carbon brushs in the motor,they will be worn out part no 8801195,round motor.or 8801097 square motor.
Mar 23, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
285 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
