Question about Panasonic SC-HT75 System
Panasonic SC-HT75 Home Theater system
When I turn my player on, display shows LOCKED, I can't do anything, only power putton works. What do to?
  • Anonymous May 10, 2008
    tried all the buttons nothings working. everythng else works except the dvd player wont open
  • Monchichi16 May 10, 2008
    tried all buttons to unlock
    everything else works except the dvd door will not open it says its locked
With the unit switched on press and hold the stop button and press the power button once. if that doesn't work then try it with the play button.
Posted on Jun 12, 2008
SOURCE:
My Panasonic SA-HT75 clicks off seconds after I turn it on. Even got a F61 code.
Open the unit and clean/replace the fan.
If it doesn't turn when you power it on after cleaning it, put some oil on its bearing sleeve.
Never power on this device while speakers are not connected!
Hope this solves your problem!
Feb 23, 2011 | Panasonic SC-HT75 System
Unit displays f61 and nothing works What component is related to this
"Check and correct the speaker cord connections. Page 7
If this does not fix the problem, there is a power supply problem. Call 1-800-211-7262 for support."
http://www.retrevo.com/support/Panasonic-SC-HT75-Home-Theater-Systems-manual/id/356ci969/t/2/
It's implying you have a shorted speaker wire.
Jan 22, 2011 | Panasonic SC-HT75 System
I have the SA. HT75 Panasonic Home theater DVD system
There is a short in the power section. Unit will also shut down.
Apr 06, 2009 | Panasonic SC-HT75 System
F61 error
I Have a panasonic mdvd home theater modl#SA-HT920, WHEN I RAISE THE VOLUME IT SHUTS DOWN AND INDICATES F61 ON THE LCD SCREEN HOW CAN I SOLVE THE PROBLEM
Feb 22, 2009 | Panasonic Home Theater System System
I need the codes to make it region free
http://www.usersmanualguide.com/panasonic/dvd_home_theater_sound_system/scht75
May 26, 2008 | Panasonic SC-HT75 System
Locked
with the unit switched on press and hold the stop button and press the power button once. if that doesn't work then try it with the play button.
May 10, 2008 | Panasonic SC-HT75 System
Panasonic SC-HT75
Is region 1 PAL? If so, and you attempt to display onto NTSC machine, you will get black and white.
Dan
Apr 23, 2008 | Panasonic SC-HT75 System
Laser/traverse deck needs replacement.Spindle motor fails to spin.If loaded disk will not turn give it a slight push to get it started.If it runs the motor is bad and the traverse deck needs replacement.Not an easy fix.You need to know specific procedures and alignments.
Dec 26, 2007 | Panasonic SC-HT75 System
My DVD Home Theater System Panasonic SC-HT 75 no sound at all.
Dec 14, 2007 | Panasonic SC-HT75 System
Panasonic SC-HT75 System Logo
398 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
