Question about Sansui Audio Players & Recorders
Sansui RA-700 reverbaration amp
How do you hook up a RA 700 reverb amp.
I have a '93 Fender Blues deluxe tweed and don't seem to have any reverb, am I missing something?
Check the connection to the reverb tank (rectangular box usually sitting on the bottom of the amp). There are a pair wires that connect it to the amp. If wires are connected, and the reverb is not working, you may need to replace the reverb tank.
Oct 16, 2016 | Fender Music
Just got a new Marshall DSL40C. The reverb does not work on either gain control or with the footswitch. Why?
Nothing wrong with the amp. Google it- these amps have extremely weak reverb. All of them are the same. It's the one weak point about these amps. And I love mine. I mic it when we gig. Sounds awesome both clean and driven. But you'll have to get a separate reverb pedal if you want "girl crush" or "pipeline" reverb. Don't listen to the above posters. It's the way these amps are.
Nov 30, 2013 | Marshall Music
The reverb channel on my fender twin feeds back
Not sure of how it is feeding back. Two possibilities... the reverb tank in the cabinet is no longer shock mounted. The other is your guitar can "hear" the speaker... make sure you are away from the amp. With the reverb on, the feedback stability is less than with it off so make sure your guitar is away from the amp. Acoustic guitars are more sensitive to this than solid body ones.
May 10, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
The problem is me not the gear (px2000) I'm not sure how to use it I've got various pieces of kit:- Mixers - Drum machines - sound modules - reverb units - three sets of speakers (2 active & 1 passive)...
Hi well to wire it all up,isn't too hard, if ya can follow the diagram above, it's a rough, very, diagram of how you could go about hooking it all up.
The AMP is sort of the central thing, the speaker plug into the OUTPUT side of things. Then on the INPUT we use our MIXER, to Join all our "Other" INPUT devices, Drums, sound modules and reverb units, the reverbs always go between the Input device and the Mixer.
Now if using a patch bay all the inputs go to that then to the Mixer and on to the Amp, out to the speakers.
You could use the PC to control them all, and use the USB audio interface to deliver audio in.
Aug 12, 2010 | Computers & Internet
Hi my Marshal G15 is making an echoy twang when played loud (& open E chords). does this mean the reverb is broken?
I suspect the vibration when it is loud is vibrating a reverb tank within the unit.
Test this bylistening with headphones and see if you get same sound.
It may be the reverb has a resonance or the cabinet does that is sensitive to your E chords.
The shock mounting of the reverb may have failed to isolate the reverb tank from speaker vibrations... hence the headphone test.
Jan 27, 2010 | Marshall 15 Watt Guitar Amp
Crate 100 head. Reverb doesn't work.
Check the input RCA plug going into the reverb tank (silver box with two wires connected to it). Make sure the amp is off when you do this. Sounds like the output is working fine if hitting the amp does it.
Jun 19, 2009 | Crate Music
Peavey bandit 112 reverb
It might just be the control knob. My fender's reverb went out and it was just the knob.
Mar 23, 2009 | Audio Players & Recorders
Crate gt 30 amp reverb wire loose. whrer does it connect?
If its the input reverb tank wire or output reverb tank wire just reconnect it (if the amp has a reverb tank).
Feb 27, 2009 | Crate Music
Sanaui
This is a device which gives the illusion of more spacious sound by adding reverberation (echo) to the audio signal. This particular unit uses a mechanical analog delay mechanism employing a steel spring! Analog spring reverb units enjoyed some popularity in the late 60's and early 70's, with the Sansui and Pioneer units being the most common..
Feb 12, 2008 | Audio Players & Recorders
Fender reverb mod both channels
Go to http://www.silvertoneamps.com/micKfender/Fender-Reverb-Both-Channels.html
there is info on this mod. heed the warnings of hot rod activities!!
There is a solution to your misguided nods you mentioned earlier.
Dec 16, 2007 | JBL Control 23 Speaker
500 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
