Frozen hard drive (disk reading error on Archos 104)
Archos 104 hard drive appears to be frozen. Device is just clicking. Had a creative and could reset it, but this doesn't appear to be the case. Msg says: read access error! can't read from hard disk.
Is there anything I can do at home please?
regards,
Des
  • 5 more comments
  • chascon Apr 10, 2008
    i have a problem with my archos 104 too.
    I cant turn it on. and when its conected to my computer, it doesnt appear on "My PC", but i can see 2 blue lights on my Archos device. One says "ON" and the other one says "CHG".
    When i try to turn it on, a hourglass appears and then the screen turns off.
    sorry for my bad english, im from chile :P
    thanks
  • Anonymous Jun 01, 2008
    My archos device has a black screen slightley lit up and the 2 lights (CHG and ON) wont go of. I dont no how to reset it
  • Des Maguire Jun 20, 2008
    FAO the guest who replied on the 14th April: I'd be interested to know how you reformatted the 104? Is there a way to do this that is not written in the manual? I can't see any access for a reset hole, to use a pin etc.
    cheers,
    and thanks,
    Des Maguire
  • psingle0405 Jul 31, 2008
    My daughter has the same problem... just getting an your glass... please please help.
    [email protected]
  • Anonymous Aug 15, 2008
    i have the same problem too but i can't see anything
  • MAGED DOKHAN Nov 03, 2008
    READ ACCESS ERROR FOR ARCHOS XS202
  • Flux123 Apr 29, 2009
    Lately i've been having to charge my player a lot more then before and when i turn on my player now it freezes up and takes a long time to load the song to play. When the song DOES start playing i can't turn up or turn down the volume or switch the song or go to any of the other menu's. How do you restart the player or is there away to change the battery or something?
Im havin the same dam problem with the lights and clickin nosie and it wont turn on im pissed
Posted on Sep 09, 2008
I had the same problem and it was also the battery, one of the soldered on terminals had broken loose, i resoldered it and its fine
Posted on Sep 02, 2008
I found the solution un my case.
The problem was the battery, it wasnt well conected, so i wasnt able to turn it off.
Posted on Jun 20, 2008
I had the same problem as well. i ended up reformatting it. but now my mac or pc will not mount it at all.
good luck.
Posted on Apr 14, 2008
SOURCE:
Recovery (code 104)
From Archos' support website FAQ:
When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted.
With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk".
Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=us&lang=en
Feb 17, 2011 | Archos 405 Digital Media Player
Archos 605 wifi frozen/bricked
there's a possible error on the disk or the archos storage, - a certain corrupt file could possibly the one making the unit into freeze..
POst back here again
Thank you
May 21, 2008 | Archos 605 WiFi Digital Media Player
Archos 405 blijtf gaan om de hertel [code 104] wat moet ik don
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=nl&lang=en
See:
It means that there is a hard drive error due to damage. The hard drive can be repaired by selecting 'Repair Disk'.
I tried to translate this for you using Google Translate, but Fixya would not allow it.
Good luck from Detroit, MI, USA.
Jan 05, 2011 | Archos 405 Digital Media Player
How do i update my Archos 504?
How to install firmware ..?(update)
Step 1. Download the firmware to your computer-->click HERE to download the update file When you download the update file, your browser may warn you that the file 'could be harmful'. This is normal because browsers are not familiar with files that have a .AOS extension and suspect that they could be malicious. These files are not harmful to your computer.
Step 2. Turn on your ARCHOS device and connect it to your computer with the USB cable
Step 3. On the ARCHOS, choose to connect and wait a few seconds for your device to be detected by the computer
Step 4. Copy and paste the downloaded firmware (.AOS file) to the ARCHOS device.
  • Case 1: logo_firm_hdd.jpg Your ARCHOS is detected by your computer as a Hard Drive (E: for example) in Windows® Explorer. Paste the update file directly onto the ARCHOS hard drive icon.
  • Case 2: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see just two folders Data and Media when you open it. Paste the update file into the folder called Data.
  • Case 3: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see Internal Hard Drive when you open it. Open this Internal Hard Drive icon and you will see the various ARCHOS folders inside (Video, Music, etc.). Paste the update file into this area but be careful not to paste it into any of the folders there.
Step 5. Disconnect the Device
Unplug the USB cable (for 'Mobile Device' connections) or use the "safe disconnect" green arrow icon (for Hard drive connection) in the system tray before unplugging the USB cable.
Step 6. On your ARCHOS device, click on "Update Firmware"
Click on the "tab" button to show the settings screen. Select the "System" icon and then click on the "Update Firmware" button. For the ARCHOS 104, 202, & 204, go to the settings and open the icon "System" where you can find the Update Firmware button.
Dec 31, 2010 | Archos 504 500870 Digital Media Player
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
Code 104
Recovert code 104
would you like to recover your system?
NO
Repair disk
Format disk
P.S. pressed the OK button on the device and its telling me to
connectto your divise to my PC and install an update file DONE
then the devise reapear back to recovery code 104
Jan 14, 2009 | Archos 405 Digital Media Player
It shows-recovery error-102 & error-104
Hi
i had same issue. nothing worked until i saw a guy who fixed his by dropping it on floor?
i dropped my archos in the protective case from 2 feet off floor. the bloody thing when came back to life, 100% good. i think the hard drive was stuck and the fall fixed it!! it cannot hurt as yours is broken still i guess. hope it works for you to
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
Gmini hard disk reading problems
My Gmini XS202s did this twice both time cause the battery went flat while moving files across (I should always charge device while connecting to PC)
First time I reformatted device as FAT32 using fdisk (Windows formatting tool should do same)
Then downloaded latest AOS and copied to root directory. [get AOS from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en]
second time I ran mkdosfs /media/disk (disk was mount point for gmini). This seemed to fix the device and I lost about 20 files. but better than reformat.
Dec 17, 2008 | Archos Gmini XS202 MP3 Player
Read hard disk error keeps coming up, computer does not recognise the [player
acer laptop 5290 won't boot up.. keeps saying "disk read error occurred" cannot get anywhere but to that screen saying that.
Jul 26, 2008 | Archos 104 MP3 Player
Format Hard Drive Error
If the unit detects any form of Hard Drive Error it asks you to format the drive. Connect the unit to your PC and run ScanDisk or DOS Chkdsk on the drive. Will help to rectify any issues with the FAT. Windows XP & 2000 Running Check Disk Utility (ChkDsk) ? HARD DRIVE mode only If you still have problems with the file system on your AV 500 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the AV 500. ? Quit all running applications. ? Properly connect the AV 500 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f . Use e: or f: or whatever drive letter is representing your AV 500. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When finished, exit the DOS Window and properly disconnect the AV 500 from your computer. Now try using the device. DO NOT try to defrag the drive. Let us know how you get on.
Jul 26, 2007 | Archos AV 500 Digital Media Player
1,180 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
