After I removed the seven screws there is something holding this together yet. I need to know what is holding this together? The reason I am taken it apart, there is something loose or broken inside. Is there something that I should know that might make the shredder only shred on the left side (not the right side very well) (the power switch side)
There are 8 screws. Two in shallow recesses and 6 in deeper recesses. The 8th screw is hidden by a warranty void sticker and is one of the deeper recessed screws.
Comments:
Jun 02, 2008
- You are probably right in that the shredder might be misaligned.
For mine, the power just went. I hope it is just a loose wire on the circuit board. The power light is on and Reverse works, but no shredding action so I hope it is just a problem with the wiring.
My sharp adding machine EL1154 was running fine and I think it came to the end of the reel. It now...
(More)
My sharp adding machine EL1154 was running fine and I think it came to the end of the reel. It now only prints red numers with an equal sign behind it . It will also print only 2 numbers instead of three.
When I turn on "Auto" it makes a sound like it is running continuously, but when I put...
(More)
When I turn on "Auto" it makes a sound like it is running continuously, but when I put paper in it does not shred
