Question about Denon AVR-2807 Receiver
No output from unit (denon avr2807)
Need help to figure out problem with the outputs.
the unit turns on but there is no sound coming out of
any outputs.
  • Denon Master
  • 1,550 Answers
El amplificador de audio IC esta dañado por eso no existe audio hay que remplazarlo.
Posted on Apr 04, 2008
I have a Denon AVR 2802. No sound output when adjusting master volume knob. When trying to solve the problem, I found out that I can achieve sound output by pressing the CH vol button and adjust individual...
try to reset. Unplug the unit, press and hold speaker A and speaker B buttons and plug the unit in outlet. If doesn't help, the unit may have a problem with microprocessor or dsp boad and need to be serviced at a repair shop.
Oct 04, 2011 | Denon AVR-2802
Denon AVR 1601 with no sound output
Sounds like Audio ouput ic's. They're located on the inside of the unit on the big heatsink. get the part number(s) of them and call you local electronics store for parts.
Jan 29, 2010 | Denon AVR-1601 Receiver
The left side main output won't put out any sound on my Denon AVR-900.
connect your right speaker cable to the left output, if the sound comes out then the problem is on the left speaker ( the cable or the speaker itself ), but if still no sound, then the problem is on the power output of the unit, need to repair them
Oct 20, 2009 | Denon AVR-900 Receiver
After playing my AVR-2802 Denon a while approx 3-4 hrs the sound output juts turns off, after letting it cool down a while it will resume playing ok , then repeats the cycle of loss of audio output.
Seems to be a heat related issue, when it " cools down " awhile it resumes audio output? Be sure you are allowing air circulation around the receiver, I am note sure but I do not think Denons have inboard fans, you could try a ciculating air fan on the unit after playing it for a couple of hours if the receiver feels hot.
Jan 30, 2009 | Denon AVR-2802
Analog output from digital input for Denon AVR 3803
On the Denon AVR-888 (and I presume others), you have to put the unit in "record" mode. This is covered under "Other Operations and Functions" in the manual. Here are the steps:
1. On the front of the unit, press the zone2/rec select button
2. Turn source select until "recout source" is displayed
3. Turn source select to choose the input source
Hope this helps.
Dec 20, 2008 | Denon AVR-3803 Receiver
Power On + red LED turns on + but final relay (click) don't come so no sound
Your audio output transistors are shorted and your unit is staying in "protect " mode to protect your speakers from 40 to 60 volts that is being sent at them from the shorted outputs. If you can use a meter you won't need the schematic MOST likely because the outputs are USUALLY the only parts that short out. The output transistors( or chip ) are mounted to the large, finned heatsink. The #'s on the transistors start with "2SA-" and "2SC-" followed by numbers. There are two output transistors per channel. If your unit uses an IC for audio output then the # on the IC will be "STK-" followed by numbers. These parts are available from Good Luck!
Oct 17, 2008 | Denon PMA-2000R 2-Channel Amplifier
Lost picture on my AVR-2807
There is a video select button on the receiver. Press it and it toggles through all of the video sources. Keep pressing it until the display says video=source.
Jul 23, 2008 | Denon AVR-2807 Receiver
Denon avr 2803
The unit is in protect mode. This effectively shuts off the output amplifier section. This happens because a problme is detected in the output section. This unit will require service. Most likely the output transistors have failed. Figure on $20-$40 for parts plus the local labor rate for repair cost.
May 12, 2008 | Audio Players & Recorders
Denon 1601 avr
The unit is in protect mode. It has detected a problem in the final output stage and has shut down to prevent further damage. Disconnect the speakers completely and try turning it on. If you still get the same symptom, the problem is inside the unit and repair is required. Usually when this occurs, the output transistors have failed. There will be at least 2 that need to be replaced. Figure on parts costing around $15-$25. Add in the local labor rate for the complete repair cost.
Apr 07, 2008 | Denon AVR-1601 Receiver
Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Jun 05, 2007 | Denon AVR-2106 Receiver
Denon AVR-2807 Receiver Logo
136 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
