Cameras Logo
Posted on Mar 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MEMORY CARD SCREEN MESSAGE SAYS THE MEMORY CARD IS PROTECTED. I HAVE TRIED AJDUSTING THE SWITCH BUT STILL CAN NOT TAKE PHOTOGRAPHS. REGARDS R. HUGHES
Anonymous
Level 2:
  • Expert 55 Answers
  • Posted on Mar 31, 2008
Anonymous
Expert
Level 2:
Answers
55
Questions
Helped
10999
Points
110
I think memory card is not supporting to your camera. check which memory card is suitable for your cam with its specification.
Memory card error
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
1helpful
I have a Fujifilm finepix digital S1000 fd camera. When I put in my batteries today, it said on the screen 'protected card'. How do I get this off so I can take photographs?
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
1helpful
Hi i bought an sd memory card inserted it into my pc and tried to put some photographs on it and i keep on getting a message saying this card is write protected have i got the wong card or can this be...
Has this SD memory card have a small slide switch on the edge of the card?
If so this slide switch allows you to write data or write protect data on the card.
3helpful
When switched on camera gives message - memory card is write prot
''Memory card is write protected''
Remove the SD memory card from the camera and move the small switch on the side to the unlock position. That should solve the problem.
1helpful
2answers
I cant copy song in memory card its shows card is write protected
What sort of memory card is it?  can you remove it and install it in a card reader directly on your pc?  What is trhe phone?
4answers
Locked Card
Change the memory card lock switch to the normal setting84b4934.jpg3c6d94b.jpg
Good luck....
1helpful
My camera says my 'memory card is protected'.. how do I take this off?
Not able to copy the photographs from the meory card but able to see the sam in the Camera LCD screen
the problem may be that you have "locked" your memory, there is a little switch on the memory card you pull it up or down, up for lock, down for unlocking..  or the problem might be with your card reader..
7helpful
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
