Question about HP LaserJet 2420dn Printer
Weird toner issues
Our HP LaserJet 2420dn is printing very dark. Whenever we print a page, the whole page comes out darker than normal. It looks like everything is in a shadow or was copied on very dark paper. Help?!? I have tried to open the printer to clean it but I can't figure out where to do so.
Kelli
  • willievoi01 May 29, 2008
    i have the same problem with darker color printing please advise how to fix this kind of problem thanks much =)
    Problem Solver:
  • 6 Answers
Check the ground connectors under the toner in the left side
Posted on Oct 13, 2009
    Problem Solver:
  • 15 Answers
Hi Kelli.i would replace the drum unitand toner!
Posted on Apr 01, 2008
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Printed pages are light on both sides of page.
This is usually a sign that the toner cartridge is running low on toner. Replace the toner cartridge and see if the problem persists. If not, then problem solved.
If the problem persists, try adjusting the darkness settings in the printer settings when you are about to print. Sometimes even one notch darker can make a large difference.
Feb 28, 2011 | HP LaserJet 2430dtn Printer
HP Laserjet 3015 - Printed pages are VERY light
Printed pages are VERY light, and the fuser temperature is low. The toner is not fixed on paper. Still it don`t give any errors. A detailed diagram of the power souce have anyone?
Nov 13, 2009 | HP LaserJet 3015 All-In-One Printer
My HP printer 2420 leaves "ghost" prints on the pages.
This can be caused by one of two things.
1. faulty wiper blade on your toner so that the previous image in not being wiped off the drum.
2. worn fuser sleve.
To work out which it is you will need to do a half stop test: print off a normal document then when it is about half way through the printer ( unfortunatly you may have to repeat this to get the timing right) open the front cover. remove the toner cartridge. if you can see the ghosting on the page the it is the toner. if its not there then its a new fuser. to save on money and if your confident enouh you may be able to just chane the fuser sleve depending on the state of the fuser on a whole.
hope this helps
feel free to email me if you have any other questions:
pete@wedotoners.com
Oct 21, 2008 | HP LaserJet 2420 Printer
HP 5550 Laserjet prints dark
The only time I saw a color laser Printing darker than normal the issue was tranfer belt. The condition you describe matches the problem I was involved in and the tranfer kit fixed the problem.
Hope this helps
Aug 28, 2008 | HP LaserJet 5550 Printer
Darker color printing
dear Friend pls check your print Quality in printer preference setting ,is it possible due to Hi density (print Resoluction)
other wise Check printer on other New computer with new Printer Drivers Installation
May 29, 2008 | HP LaserJet 2420dn Printer
Hp laser jet 2420d printer
check the scan unit or change it
Mar 22, 2008 | HP LaserJet 2420dn Printer
HP 2420dn printing gray and shadows
maybe the scan unit need to clean first you most sure that the toner cartridge is original and new then start clean th scan unit reflector d9b88f3.jpg
Mar 12, 2008 | HP LaserJet 2420dn Printer
Printing pages dark
The cartridge itself needs to be replaced, threre is a blade called the drum cleaning blade which scrapes toner off the Drum(blue roller) it is not cleaning the excess toner.
Oct 16, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 2420dn Printer Logo
141 people viewed this question
Seeker5211
Seeker5211
