Question about Sylvania SRD3900 DVD Player/VCR
ERROR CODES E24 ~& E4 54037380 ON MY DVD RECORDER, CAN ANYONE TELL ME WHAT THESE MEAN, THANKS
  • surveypgo May 08, 2008
    I'm having the same problem. I have cleaned the lens several times but still getting this error. If I am going to have to buy new dvd's to record on every few months then this DVD-RW is gonna cost a fortune in discs. Even getting this message trying to format brand new discs. It's a dual vcr/dvd recorder and if I'd known I was gonna have such problems I'd have stuck with my old vcr and not wasted the money on this great new dvd/vcr recorder.
  • Jmullin2 Jul 06, 2008
    i just googled this code and found this.. i have the same error message... i also have no time function.. i set my time, and it stays at what time i set it.. so i can't record anything on a timed basis..
    i have cleaned my lens and it worked for a few more times, but now i finished a 4 hour disc, and when i went to finalize it, this pops up.. i too am wondering if this was a poor made equipment?
If you are trying to record vhs tapes to the dvr side, first you need to get 1x up to 8x DVD-R dvds. You can find them on ebay. The machine has problems recognizing the up to 16x type. Put the blank DVD in and let it load. Then start playing (not dubbing but playing) the videotape for at least 6-8 seconds. If you have somewhat of a lead-in on the videotape you can let it go even 10 seconds. Only after the videotape has been playing for this period of time, press the dubbing button. If the error code does come up, rewind the tape and start again, but in most cases the error code will not happen if you do it like this.
Posted on May 26, 2008
If you are trying to record from a vhs tape to a dvd, first of all you'll need to buy only 1x-8x dvd-r dvds. You can find the 4x or 8x on ebay. This recorder has a problem with the up to 16x. Put the DVD-R in and let it load. Put the videotape in. Press play on the videotape side - not dubbing but play - and let the videotape play for 6-10 seconds and THEN press the dubbing button. If you have somewhat of a lead-in on the videotape you won't lose anything. At most otherwise you'll lose 6-10 seconds. If the error code comes up, rewind the tape, and start again. Letting the videotape run for a bit first before pressing dubbing seems to prevent this problem, at least for me, and I was getting the error code every time.
6ya staff
SOURCE:
Get error code E24. What does this mean?
What are you trying to do when the E24 message appears?
Mar 05, 2015 | Philips Magnavox MWR20V6 DVD Recorder/VCR
What does e24 error on my siemens tumble dryer mean ? After about 10 mins the machine make an alert warning noise and flashes the error sign and said turn off and start again .
Unfortunately, it means you have a computerized machine that can only be repaired by a technician with proper diagnosing equipment. Even if you can find out the meaning of the code... that may not tell you what to do about it. (It usually involves replacing circuit boards). Monetarily, with regard to cost of repairs, we were all far better off back in the days of ''switches'', ''knobs'' and ''mechanical timers''.
Sep 01, 2014 | Siemens WT46W568GB Condenser Tumble Dryer,...
E24 error
Hello Dana, this is Z. I am happy to assist you!
If you are getting an error code E24 on your Electrolux washer, it usually means one of three things: your drain pump relay has failed, a wire may be disconnected from the pump, or your main control board needs replacing. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards.
Mar 18, 2014 | Electrolux Washing Machines
Problem with Juki DDL-5550N-7 Sewing Machine, Error Code E24
El Drv se refiere a la tarjeta interna que controla el motor, est? se encuentra da?ada.
Email: [email protected]
May 11, 2012 | Juki Sewing Machines
Error E24 when trying to record on symphonic vhs/dvd recorder have tried multiple brands of disc using dvd-r like directions say....arg
My BBK DW9937S dead too. But I changed its DVDWriter to NEC5170 (and now I've got an DW9938 because I can burn even DVD-R/RW disks too).
As I mentioned above almost any combo VHS/DVDwriter has the IDE DVDRW inside (I hope you guess how to fix it)
Jun 06, 2011 | Symphonic SR90VE
What is the error e24?
first you must clean the laser whith alcohol,second try to change a dvd disc.
Mar 13, 2010 | Emerson EWR10D4 DVD Recorder
Won't record and never has. get disk error e24
Anyone know where I could get a free download for a Emerson Dvd/vcr combo firmware upgrade??? (Ewr20v4) I need it right away . Emerson will charge to mail me one.
Nov 14, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Feb 08, 2009 | Sharp DV-RW340U DVD Recorder/VCR
Can't record to DVD
make sure it is a dvd-4 8x or lower if you have the service pac....4x or lower if not. 2x dvd-rw. hope it helps
Jan 27, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Sylvania zv420SL8 error code E4
The error is actually a catch all for three problems or a better way of putting it three problems can generate this error Sylvania requires that you call them with the error code to get an answer on which of the three errors it could be, However I can tell you from working on these units that the issue has to do with recording laser power.
Oct 09, 2007 | Televison & Video
Sylvania SRD3900 DVD Player/VCR Logo
963 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
