Question about Canon PowerShot A570 IS Digital Camera
White pictures when we take a picture, it picks up so much light that you can hardly tell what the picture is taken of. how do i adjust shudder speed? camera type is canon power shot a570is.
Maybe you are shooting in the manual mode (shown as "M" on the dial) with an incorrect exposure setting. Make sure that the dial is in "Auto" mode to check if it will shoot correctly then. If you are still getting the white picture on "Auto", then it may be a defective image sensor in the camera - clearly a warranty claim.
Posted on May 16, 2008
Camera exilim ex-s600 will not take pictures outside,pictures turning out white,yet will take pictures inside ok.is this a worthwhile repair
This seems to be a software problem with your camera. Your camera should, if on AUTO mode, automatically expose your photo accurately. Try half pressing the shutter button (used to take pictures) while outside to adjust focus and exposure, then press the button fully to take picture. If your camera cannot adjust to take a properly exposed picture (not bright white), then it is possible that the shutter speed is stuck on a too high speed, outside daytime shutter speed should be fast (1/1000 sec). Or if your shutter speed adjust accurately, it could be the aperture if the aperture is not small enough for daylight shooting. This is likely a software problem. Try adjusting your settings manually and see if the picture turns out!
Sep 10, 2011 | Casio EXILIM Card EX-S770 Digital Camera
What is mode ?there are some pictures on the screen for using different modes but I don't when I should use them.Can I have a manual?
Mode is a behavior setting for the camera. The most common is "automatic" and this will rely on the camera to adjust settings like shudder speed and focus. But sometimes you need more control...
"Night" - will assume you need a very long shudder speed. while the camera will take pictures in lower amounts of light, you also have to work harder to keep the camera still.
"Portrait" - This mode will adjust the automatic focus assuming that regardless of activity in the background that you want a picture of the object or individual directly in front of the camera
"Video" - Takes low quality video instead of high quality still shots.
"Landscape\Panoramic" - This setting is the opposite of portrait and assumes that the landscape is the main focus of the picture regardless of activity in front of the camera.
Other Modes: Cameras may have other modes that similarly allow for specialized photos. Some examples would be Black and white, color filters, light filtering, and overlays.
Mar 26, 2010 | Samsung Slim Zoom 1150 Point and Shoot...
I cant get into my camera function
From the BlackBerry Curve 8520 Home screen, press the Camera key on the side of the phone > Press the Menu key > Scroll to and select Options > Scroll to and select the desired setting: * White Balance : This setting changes the contrast of the pictures taken to optimal for the listed conditions:
o Automatic: The device automatically adjusts the contrast for each picture.
o Sunny: Ideal for outdoor pictures on a sunny day.
o Cloudy: Ideal for outdoor pictures on a cloudy day.
o Night: Ideal for pictures in low-light conditions.
o Incandescent: Ideal for indoor pictures with incandescent lighting.
o Fluorescent: Ideal for indoor pictures with fluorescent lighting.
* Picture Size: To change the size of pictures taken. Larger pictures require more storage space.
o Large (1600 x 1200)
o Medium (1024 x 768)
o Small (640 x 480)
* Picture Quality: To change the quality of pictures taken. Finer quality pictures require more storage space.
o Superfine: Best quality
o Fine: Medium quality
o Normal: Lowest quality
* Color Effect
o Normal: To take color pictures.
o Black & White: To take black and white pictures.
o Sepia: To take pictures with a sepia tint for an old-fashioned look.
* Store Pictures: This gives you the option to store pictures you take to either the device memory or the media card, if available.
* Folder: To change the default storage location for pictures taken with the camera.
After you adjust your BlackBerry Curve camera settings, pess the Menu key and select save.
Nov 19, 2009 | RIM BlackBerry Curve 8520 Smartphone
What is and how do i adjust the white balnceon my fujitsu S550 digital camers?
Adjustment is in the menu screen, you shouldn't have to go very deep as it is a frequently adjusted setting.
White Balance is how the camera interprets white depending on ambient lighting. Have you ever noticed how when you are taking pictures inside at night and all of the light comes from lamps and the flash that your pictures have a yellow look? Take a picture under flourescent lamps and the pictures look different as well? How about outside? Best true color rendition on the picture taken outside, but different than the others.
White balance is a way for the photographer to adjust the tone of the picture to accurately reproduce the true colors seen in real life in the picture. Most cameras have an automatic white balance and they usually work fairly well. But for the best results, set it manually. Your whites will be white and skin tones appear accurate.
Hope this helps! Good Luck!
Oct 06, 2009 | Fujitsu Cameras
I cano not take outdoor pictures its all white
shutter is sticking so it over exposes photos . will need shutter or lens assembly replaced. it will have banding stripes in low light and white in bright light.
Apr 17, 2009 | Samsung L700 Digital Camera
Picture is white
Don't know your specific camera, but it sounds like you have it set on manual (does it have P, A, S, M settings?) with a long shutter speed. This would let in a lot of light outside, and make all of your pictures blurry.
Change your setting to P (program) or Auto (automatic) and see if that helps.
Mar 18, 2009 | BenQ DC E53 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Pictures too dark
The settings in Auto Mode are factory set. If you want to adjust exposure and shutter speeds then you will have to shoot in Manual Mode (TV=Shutter Priority, AV=Aperture Priority, M=Full Manual)
May 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Samsung Digimax 430
It may be due to domestic lighting.Light-bulbs give off waves in the orange spectrum whereas flourescent tubes cast a greenish hue.
Dec 28, 2006 | Samsung Digimax 430 Digital Camera
One of the pictures has a great blue sky but the green tree is very dark and the other one has the green tree and very bright sky?
The two pictures were shot at dramatically different exposures - the "dark" one at 1/1600 shutter speed, f7.3, the "light" one at 1/320 shutter speed, f4.0. This accounts for the great difference, as the exposure conditions for the "light" one allowed much more light into the image during the exposure period. You didn't tell the whole story of how you set this up, I think you were shooting in a "spot" metering mode, where the particular exposure conditions the camera uses would vary considerably whether you were aiming at a dark area (making the picture light) or a light area (making the picture dark). I would make two recommendations: Switch your metering mode to "center weighted" (the mode labeled "[(•)]"), and also change your ISO setting to AUTO, as there would be no reason for shooting these photos at ISO 200 that I can think of.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
