Question about Denon DN-961FA CD Player
Denon UD-M3 CD Receiver CD playing
The unit will not play a CD in the normal horizontal position. If the front is raised so that it is tilted at about 20 degrees to the horizontal then it works perfectly. Is there a simple solution to the problem?
    Scholar:
  • 54 Answers
Sounds like your spindle motor is shot. What happens is, the bushings in the motor that turns the CD disk are worn. So tilting the unit will change the loading of the motor shaft to an " un-worn" spot on the bushings and the CD plays properly. The spindle motors are chepa for the most part, but the labour might bite you a little because it is a fairly involved job. If the unit is still under warranty....great...if it is just off warranty, you may get some good will service from Denon......best of luck...Rob
Posted on Apr 21, 2008
SOURCE:
Cd stuck in Denon CD auto changer receiver. Displays ERR. How can I get out?
As there may be other factors at play that require a more detailed explanation, I would suggest that you seek a resolution through a discussion with a qualified technician. To do this, refer to your operating manual, which should provide a telephone number for technical contact assistance. You can also go up to the manufacturer's website and make contact for advice. www.denon.com/
Mar 05, 2015 | Denon Audio Players & Recorders
How to set time on denon ud-m3
press 'display' for 4 sec, then change hr with left arror, min with right arrow. easy
Mar 26, 2012 | Denon CDR-M30 CD Recorder
Denon DCM-370/270 - issue playing CD's. A CD will
I would replace the audio cable from the CD player to the Denon amp, a long shot, if you have other devices hooked to the amp and plays fine, the problem will be in the CD player. However! if all sound sources have the same problem, the issue is with the Denon unit.
Mar 09, 2012 | Denon Audio Players & Recorders
Denon CD receiver - Auxiliary function not working
this is front headfones nearby cd player control knob
Nov 22, 2009 | Audio Players & Recorders
CD DRAWER DOESNT OPEN
Is there a small hole on the front of the load tray? If there is use a straightened out paperclip to push into the hole to remove the stuck cd. That might help you out.
Nov 19, 2009 | Denon Audio Players & Recorders
Setting the clock on a Denon UD-M30 CD-R
1. press the menu/set button on component to select display mode
2. use the +/- button to set the time mode (AM 12:00 blinks)
3. press the menu/set button for at least 2 seconds (the hour will start blinking)
4. Use the +/- button to set the hour, must roll the hour to change am/pm
5. press the menu/set button to switch to minutes
6. use the +/- button to set minutes
7. press the menu/set button to finish setting the time
Dec 15, 2008 | Denon CDR-M30 CD Recorder
Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
May 24, 2008 | Denon AVR-1803 Receiver
Denon UD M31 CD not playing
It is possible that the laser has gone, the part you require is:
Sanyo SF-P101N CD Mechanism - 16 pins (there are 15 pin versions available which have the same product number, the two versions are incompatible)
i have found the part on Ebay (UK) for less than £5, the shop that sells it also suggest replacing the flexible strip that connects that mechanism to the circuit board, the strip costs £2 and replacing it would seem to be a very sensible idea seeing as you have to completely strip the unit to replace the mechanism.
My UD-M31 is in bits on my work bench at present, awaiting the arrival of a new mechanism, i'll post again if replacing it solves the problem.
Jan 01, 2008 | Audio Players & Recorders
Denon UD-M50 amp/3 cd changer
The tact switch behind the panel is being pushed in by a defective front panel button, the small switch is bad behind the button, or the volume control IC is bad. Good Luck
Aug 11, 2007 | Denon DCM-35 CD Player
Denon DN-961FA CD Player Logo
625 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
