Question about Onkyo TX-SR605 Receiver
Volume when you turn the valume up to 60 to 70 it shuts off the receiver
Probably have the limit volume set. try adjusting the audio hardware setup it is in the manual under advanced features.
Posted on Apr 01, 2008
SOURCE:
I had onkyo 5.1 hometheater i cant raise the volume more than 40 how can i fix the problem ?
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
May 28, 2015 | Onkyo TXSR309 5.1 Channel Home Theater...
How to repair a onkyo A-812XG if a volume is higher the unit is shutdown
Hi Ryan, It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com, Thanks, JT
Apr 26, 2015 | Onkyo Audio Players & Recorders
My samsung freeform iii wont let me adjust the master valume
When you ring somebody use the L R UP-DOWN button in the middle of your phone to increase the volume.
Aug 17, 2012 | Samsung Freeform Iii 3 Black Metropcs...
I am useing 5230 nokia mobile, i want more valume on my set, how can i get more valume in my mobile set.
Hi nirmal_ku963,
Check on the side of the phone.
There should be a button for up and down.
these are the volume buttons.
I Hope this helps.
Jun 20, 2011 | Nokia 5230 Cell Phone
How do I hook the cabels so I can control the valume with the TV remote?
What type receiver and which component do you want to control the volume? Give me model numbers and is it a separate component. Usually the remote should control the receiver volume. and anything connect to it. Is this a car stereo or a home system? If its a home system even if its new. It might be bad batteries or bad remote. Let me know more.
Dec 25, 2010 | Audio Players & Recorders
Keeps turning itself off
If Both speakers are working at a low volume and you turn it up and it clips and shuts off you have one of 3 problems. you have over driven your speakers and one has shorted the voice coil but still will work at low volume, its a overload protection for ohms short in receiver. unhook each speaker and turn balance to the one hooked up and turn up receiver if it shuts off do the same with other speaker to determine which side is bad. 2 speaker wires are touching at speaker or receiver. 3 a bad receiver output transister. Good luck.
May 23, 2010 | Sherwood RX-4109
Whent turn up the valume sound whit no power
I would contact Adcom for a service place near you
Feb 17, 2010 | Adcom GFA-5400 2-Channel Amplifier
W550i volume is not working
U HAVE 2 CHANGE DA VALUME SWITCH IMRAN 9880400390
Aug 19, 2009 | Sony Ericsson W550i Cellular Phone
Receiver shuts off when volume raised above 10
A fuse breaker or resetting electronic componet device attaced to the audio receiver protects the amp & speakers for destruction! The quality of the amp ,spkers& spks. wires help on choosing for protection shut downs! Of course at 10 volume you risk all of the amp in the receiver , buy a higher quality brand reciever ,intergrated amp, single amp . BE CAREFUL AT THE HIGHER VOLUME RATINGS YOU RISK HEARING DAMAGE! FOR REAL!
Feb 04, 2009 | Philips FR975 Receiver
Onkyo TX-SR605 Receiver Logo
78 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
