Question about RIM BlackBerry Pearl 8100
My Blackberry pearl will not charge
I plugged it in the charger yesterday, and it would charge for a few seconds and then stop working. There is no water damage, and its the same way with a different usb cable. Any suggestions? I called and should get a new one soon, but I really need it on soon and it's dead.
  • 3 more comments
  • henne7 Jan 02, 2009
    I have the same problem only it wont even charge for the slightest bit of time.
  • m_charles Apr 07, 2009
    Have the same problem. Paid to have the USB port replaced but problem still exists. Phone recognizes charger when plugged in but goes dead after a few seconds.
  • missprincess Apr 08, 2009
    I have switched batteries and tried different chargers, but my blackberry will not charge at all. The light won't even blink. Any Help?
  • midnit9 Apr 25, 2009
    I have the same problem wall charger wont charge I went to the official store to purchase new charger and it would not charge either
    But when I use my car carger it charges ok
    I even told the store guy and he had no clue why it would do that
    very frustrating
    its true they are piece of junk dont ever buy them
  • rachel_lee Apr 26, 2009
    My blakberry i just recieved wont turn on but only for a few seconds and is costantly blinking red. the charger wont charge it tho and the car charger only for a few seconds
So none is solving this one? WTF do I do with the phone now?
Posted on Apr 09, 2010
Upgrade software.
Posted on Apr 02, 2008
When i plug my blackberry pearl in its charger nothing happens. It wont turn on or nothing.
try a secondary battery as well as a second charger (I believe the pearl uses micro USB, which is also used by bluetooth headsets, other phones, and pcs- you could even plug it into a pc with the cable to see if it charges)
If neither works, the phone is unfortunately dead. However if the battery works, bad battery. If the different charger works, bad charger
Mar 31, 2011 | RIM BlackBerry Pearl 8100
My blackberry pearl wont charge
If it won't charge with the AC adapter, have you tried using the car charger? It may just be the adapter that doesn't work. You can also plug it into your computer with the USB cable and see if it will charge that way.
Aug 02, 2010 | RIM BlackBerry Pearl 8100
I have owned my Pearl for about 4 years I stopped using it around 2 years ago due to the trackerball not working correctly. i have spradicly pluged it in to retrieve old numbers, pictures, see if there was...
Your initial thought is probably the answer, the battery has internally short circuited due to age. In this case, the charger cannot produce enough energy to overpower the battery's consumption. While I do not recommend trying this, a tech center I worked at would "shock" a battery back to life by connecting it to a car charger for a few seconds to eek a few more weeks or months of use out of one. Again, I don't recommend this as a battery can explode and cause harm when treated this way.
Mar 05, 2010 | RIM BlackBerry Pearl 8100
My Blackberry suddenly quite working and would not turn off so I pulled the battery and then tried again but all I get is a red light for 10 seconds then nothing.
I left the battery out all night and then reinserted it and plugged the phone into the charger to charge up the battery. As soon as the charger was connected the Blackberry it fired up normally. Go figure!
Jan 30, 2010 | RIM BlackBerry Pearl 8100
I cant get my blackberry pearl to charge!
Yes I would take it back to your purchase place for repair or replacement. Only other way to charge is by using an external battery charger: http://www.amazon.com/External-Battery-Charger-Original-Blackberry/dp/B001MEV8LI/ref=sr_1_7?ie=UTF8&s=wireless&qid=1263336321&sr=8-7
Jan 11, 2010 | RIM BlackBerry Pearl 8100
I am getting that 523 error on my refurbished 8330 blackberry. was working fine yesterday
Take the battery out and put it back in after 30 seconds or so. While the device is rebooting (or while the hourglass is still spinning), .plug it into the PC Then open the application loader and remove the 3rd-party application that's causing the issue
Jan 03, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry charge symbol appears but does not charge battery
are you using the charger that came with the BlackBerry?  cause sometimes that can make a difference.
otherwise you might just need to get a new charger.
and usually the wall chargers work the best.
i had a BlackBerry Pearl 8100 and the same thing happened to mine.
Aug 20, 2009 | RIM Blackberry Curve 8300
My pearl stopped taking a charge when my son put his SIM card it.Any ideas on why it would stop charging?
Charger pin may have not plugged in properly from both the end ..try charging it with the help of USB cable by connecting to computer and also check with the charging pin whether is there any faulty in USB cable or charger....
If everything is fine contact service center
Aug 13, 2009 | RIM BlackBerry Pearl 8100
The battery on my blackberry 8310 went dead. I
ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
Apr 01, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
RIM BlackBerry  Pearl  8100 Logo
1,387 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
