Toshiba equium L10-300 problems
A couple of problems. My internet screen is always too big and won't fit, how can i make it fit s i don't have to keep scrolling across.
Secondly, trying to set up wireless with my sky package but when i use ipass on my work computer it cannot aqquire an address am i doing anything wrong??
Also it has just started but the bar along the bottom of the screen keeps going off and when i go to the down arrw in the bottom corner it keeps ppping up and really annoying??
    Sergeant:
  • 201 Answers
Hey there stuart cdm, the task bar problem can be solved by scrolling down to the taskbar and right clicking on it to reveal a box which has properties listed on it. Left click on properties, and choose your options, you can uncheck the keep the taskbar on top of other windows option. You should also experiment with the other options checked to see which ones you prefer.
The size of the internet screen can be adjusted by clicking on the box next to the red X at the top right corner. then move your pointer to the right or left edge of the window and go back and forth until the arrow appears. When the arrow is visible, hold down left button on the pointer, and slide side to side until you get the size you prefer. You can also do this for the top or bottom, or on corners it will give you a diagonal arrow and allows you to expand or shrink the window easily. You can use this function to adjust the window size for any function and your pc should remember your last setting and keep it until you change it again. Good Luck!
Posted on Mar 31, 2008
Can i install a 320 Gb HDD as secondary in Toshiba equium 3200M?
hi,
this system as I see it has the ablility to add a second hard drive so long as it is an IDE ata 133 type drive.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Jul 19, 2011 | Toshiba Equium 3200M (PV1058U-4CNS2) PC...
How can I stop my Toshiba Equium from overheating and crashing. This usually happens after about an hours use but also it always occurs (almost immediately) when I try to transfer big files such as videos...
If the air ways are clear and the fan is running fast, does it blow lots of hot air or would you expect it to blow more. Try cleaning the exhaust side of the uProcessor fan out with a vacuum cleaner and use fresh heat sink compound on the uProcessor heat sink..
If it still gives trouble, browse toshiba.com for a BIOS update to speed the fan up.
Hope that helps.
Jan 03, 2011 | Toshiba Equium 7100S PC Desktop
Where will i get a motherboard for toshiba equium L10-200 laptopis there any other motherboards that will fit.
Go on the internet or contact Toshiba. Hope this helps!?
Please rate solution - Thanks
May 15, 2010 | Computers & Internet
Equium 100 PC Desktop: my sscreen has rotated on my Toshiba EQUIUM A100-0...
hold ctrl+alt and press the up or down key to change the screen to its original position
May 05, 2010 | Toshiba Equium 100 PC Desktop
My toshiba equium laptop keeps randomly turning itself off - this could be after 5 mins or after 60 mins, but could be fine for a couple of days!!!
Hi:
your symptoms point towards a intermittent cooling problem...You might need to remove your cpu cooling fan, clean it up, and re install it, with new thermal paste. Make sure all fans in your computer are working as they should, including the power supply fan too.
Nov 20, 2009 | Toshiba Equium 100 PC Desktop
Windows 98 Drivers for Toshiba Equium L10
hi,
You should be able to download the drivers your need from this site:
http://www.driverfall.com/show/415751/toshiba-7100s.html
Good Luck!! and let me know if the helps.
Thanks.
Joe
Mar 27, 2009 | Toshiba Equium 7100S PC Desktop
Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Jan 19, 2009 | Toshiba Satellite A60 Notebook
Screen resolution
you will need to reinstall your video/display drivers and make sure you download the correct ones for the site. (toshiba's site).
Jun 19, 2008 | Toshiba Equium 6200M (PV1026U-01A) PC...
Toshiba Equium Laptop m50-164
Hi, Alex,
I think you may have deleted your audio file driver on your laptop the only way to get your sound back is to re-install your audio driver for your laptop as the sound card on your laptop is ok you can find sound card drivers on the internet if you don`t have the drivers for your sound card
Jan 08, 2008 | Audio Players & Recorders
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
