Voice recorder or transcriber that has 10 or more folders
I am a home builder and I had(as in has expired) an old Voice It brand pocket recorder that I could use up to 99 folders (that I could assign names to each). Each folder or job folder would then keep each date stamped entry I made in its appropriate folder for me to review and edit. All I can find is recorders that hold up to 7 folders. Do you know of any brands that will do what my old recorder could do. It also supported dragon software for voice to text editing.
  • Bubba Jr Apr 02, 2008
    Model # does not apply, Voice It is out of the recorder business! I am looking for another brand that will do the same. Thank you
    Both recorders recommended, as I understand, only have 2 or four folders to store the files in. I am looking for 10 or more folders.
    Genius:
  • 1,665 Answers
PLEASE GIVE MAKE AND MODEL NUMBER
Posted on Mar 31, 2008
SOURCE:
Cannot run philips LFH9398 pocket memo on my mac
the philips models are not MAC compatible. However, they normally show up as a folder and you can copy files.
Apr 29, 2011 | Philips Pocket Memo 9360 Handheld Digital...
How do I reset to factory defaults
You can download the manual for this machine at www.dictation.philips.com in the support section.
Feb 22, 2010 | Philips Pocket Memo 9360 Handheld Digital...
No voice recognition
You must have already set up and trained a user with the Dragon NaturallySpeaking software prior to transcription. Make sure that the Digital Voice Editor (DVE) software is not opened prior to starting these steps.
Open the Dragon NaturallySpeaking software.
The Dragon Bar window opens. From the Dragon Bar menu, click the Sound button.
From the Sound button, select the Transcribe Recording menu item.
The Transcribe a Recording dialog box opens.
Click the large square button to the left to start the DVE software.
The Digital Voice Editor window opens.
NOTE: If the file you want to transcribe is still on the Integrated Chip (IC) recorder (which will be reflected on the left side in the IC Recorder window), you will need to connect the IC recorder to the computer using the supplied USB cable, or transfer the file to the computer.
Select the item you want to transcribe from the PC window on the right side.
Click on File from the tool bar.
Select the Voice Recognition menu item.
The Converting.. Dialog box opens.
The Transcription Options dialog box opens.
Click the Transcribe button to continue.
The Transcribing window and Dragon Pad window opens.
The text is displayed while the transcription is in process.
NOTE: Once the transcription is complete, it may be necessary to make grammar, word, punctuation, and formatting adjustments.
To save the text file, click on File from the tool bar.
Select the Save As. Menu item.
The Save As dialog box opens.
Browse to the folder location to which you want to save the text file and double-click on that folder.
The folder you chose should now be showing in the Save in drop-down box near the top.
Type in the desired File name in the File name drop-down box towards the bottom and then select the document type.
Click the Save button.
Click the X (close) button in the upper-right corner to close the Dragon Pad window.
Click the X (close) button in the upper-right corner to close the Digital Voice Editor software.
Feb 10, 2010 | Sony ICDSX68 Digital Voice Recorder
Deleting recordings off sony icd-mx20
Display the folder o message in the folder that you want to erase.
Press Menu and select Erase by using up arrow down arrow and then press play stop button, the cursor moves to erase menu.
Press up arrow down arrows to select erases all the messages or message in a folder.
Press up or down arrow to confirm say yes and press play
Press stop to exit.
Mar 31, 2009 | Sony ICD-MX20 Digital Voice Recorder
Panasonic RR-830 only rewinds and fast-forwards, will not play
If the foot pedal is pluged in, press the play button and then you should be able to activate it with the pedal.
Jul 30, 2008 | Panasonic RR-830 Desktop Cassette...
Configuring folders
Right Click Folder A, then select Properties, then click on RESTORE DEFAULTS. That should remove that red X.
Aug 21, 2007 | Olympus AS-4000 Desktop Digital Voice...
80 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
