Washing machine My washer will not advance through the cycles. I can manually switch from fill to agitate to rinse to spin, but it will not do it on its own.
  • Kristie Harrington Apr 01, 2008
    Whirlpool, 7 cycle 3 speed, LSR7010PQ0
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Could you please post back with your manufacturer and model number? I believe you may have a bad timer motor, but need to know what type of washer it is before I make that assumption.
  • 5,911 Answers
The timer for your washer can be found at repairclinic.com. Just type in your model number in the Search menu. It is listed as item number 1060744 and costs about $66.00. There's also a repair manual available for about $16.00 listed as item number 1170635.
Searsparstdirect.com also carries the part for about the same price. It is listed under the "Controls and Rear Panel Parts" section after you type in your model number. It is listed as item number 9 in the parts illustrations and the part number is 8546685. The Sears website also carries a repair manual under the "Top and Cabinet Parts" section as item number 1G (part number 4313896) that costs about $15.00.
I mentioned the repair manual just in case you wanted it as a reference for future repairs. Of all the washers I've worked on, this is one of the easiest machines to troubleshoot and repair. I hope this helps you. Please post back if you need further assistance.
Posted on Apr 01, 2008
  • 641 Answers
SOURCE: Maytag Atlantis MAV6257AWW
Well done !
Posted on Jul 30, 2007
the dr
  • 447 Answers
SOURCE: washing machine
check the lid switch
Posted on Oct 19, 2007
  • 1214 Answers
SOURCE: GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Posted on Jan 26, 2009
  • 582 Answers
SOURCE: washing machine will not advance through the wash cycle
when it reaches the stopping point does it stop after the wash cycle if so try pushing the switch to the lid with a popsicle stick and see if it goes into the spin cycleif it does the lid switch is bad. the washer will not go into the spin cycle unless the lid is closed and if the swich is bad it won't let the time advance
Posted on Aug 12, 2009
  • 57 Answers
SOURCE: The agitator will not spin
The problem will be in the pressure starter kindly check whether water stops after certain level and ready for washing,if it is OK means kindly check the wire connections from the operational panel to the motor, in most of the case the timer will not send signal to the motor for that kindly change the operational panel and check it
Posted on May 18, 2010
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore 70 Series Washer Won't advance in the
    Bad timer. Try to find a used one if possible, this item is a little expensive.
    Aug 23, 2010 | Kenmore Washing Machines
    It keeps getting stuck on rinse cycle a
    Check it out....
    Good Luck!!
    thanks
    Jul 19, 2009 | Fisher and Paykel Washing Machines
    The washing machinge is not completing the complete cycle
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Maytag washer wont start after it fills
    Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
    Mar 14, 2009 | Maytag Washing Machines
    Jan 26, 2009 | GE WBSR3140DW Top Load Washer
    Whirlpool Washer will not progress to the rince cycle.
    that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
    I quote from : The cycle doesn't advance
    The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Washing Machines Logo
    224 people viewed this question
    Top Washing Machines Experts
