U need a new battery u arent' suppose to jump motorcycle batteries you probably killed the cells def. have to buy a new one
What did you use to jump it? hopefully not a car or truck, especially if they're running. a regular automotve battery carries way too much amperage compared to a motorcycle battery. they can also fry the ECU (main computer of the bike) by jump starting from a car. either way you shocked your battery and burned the cells inside. don't use it anymore or your taking a change of it exploding on you.
SOURCE: I had to jump my 2007 kawasaki zx6r and now the
Bad battery, or voltage regulator is bad.smoking is realy bad , loose wires or bad ends on the wires in the charging system could make it loose the charge and cause you to need to jump start it.NEW battery Check charging system for proper voltage.
