Question about Bernina Artista 170
Bernina artista 170 embroidery module
After installing artista v3 on my windows 98 computer I reconnected embroidery module ( had been sewing earlier) machine alone and computer would not either recognize it, it just came up sewing screen and said it was not connected on the computer. I have used it alot before with computer and without and it worked ok. The computer is not online.
SOURCE:
bargainbox
  • 1388 Answers
SOURCE: #50 walking foot instructions
The arm on the walking foot needs to be above the needle clamp to be lifted as the needle moves.
Posted on Sep 02, 2009
SOURCE: DOES THE BERNINA BERNETTE DECO 600 ACCEPT .ART
Not sure if you found anything out, but Deco 600 uses PES format only.
If you have the software (Deco Wizard) sometimes you can change it to PES and save the design.
Good luck
Posted on Feb 15, 2010
  • 121 Answers
SOURCE: Do I need to oil the Bernina Artista 170? If so,
- yes \-every 3-5 hours of sewing or more if you are sewing very dirty fabrics (used canvas etc)
-remove the shuttle, clean and oil the "race" where the shuttle ocellates
-remove the light cover with the off set torues wrench included with your machine
oil the needle bar, take up lefver joints and the presserfoot bar. any thing more should be done by a qualified technicial who should remove back and front covers and remove lint and dirt and then oil all the bearings
drtension
Posted on May 02, 2010
SewExpress
  • 41 Answers
SOURCE: USB to Serial port cable for Bernina Artista 180
Just happen to be sitting in front a Bernina 180 at this very moment - with the connecting cable attached to a Keyspan USA-19HS Adapter. It is a current adapter available from either Keyspan (www.keyspan.com) or any number of computer retailers - physical or online. Seems to run around $30.00 just about everywhere. Auction sites may have bargain. Worked like a charm on an older XP computer as I was able to test the older software I had due to it having the necessary parallel port the the older dongle. While I am fairly certain this combination would also work on my Windows 7 computer, I am unable to test it as I have not come across a parallel adapter that will work with the older software parallel dongle. I've had other programs/peripherals that utilize usb to serial adapter (on my Windows 7) that have worked fine, so I suspect this would also be the case.
Hope this helps. If you have specific questions, please don't hesitate to contact us.
Happy stitching,
Kim
www.sewingexpressions.com
Posted on Jun 27, 2010
RickE1
  • 202 Answers
SOURCE: Artista embroidery program version 3.0 and Windows 7
For other versions and probably yours...
You'll need the following service packs to use BERNINA Embroidery Software V5 aand under Windows® 7 / Windows Vista™ operating system:
  • Service Pack 2 for BERNINA Embroidery Software V5 (V5.0W)
  • Aurora driver for 64-bit Windows® operating systems
  • Latest dongle driver
  • EConPC 3.1 & ADX 7.14
You'll find them at www.bernina.com\downloads
Hope this helped.
Rick
Posted on Jul 12, 2010
Is bernina artista 180 embroidery module compatible with bernina artista 170
Yes, The BERNINA Artista 180 and the BERNINA Artista 170 do in fact use the same Embroidery Module.
Sep 28, 2015 | Bernina Artista 170
Bernina Artista 180 firmware question: I sold a Bernina Artista 180 sewing/embroidery machine. This machine was from 1999 and never had any firmware updated. The embroidery module was damaged in sh
I'm not exactly sure what you need but I'll give you a web site where I believe you will have good results:
http://www.ebay.com/bhp/bernina-software
Dec 15, 2014 | Bernina Artista 180
Why wont my Bernina 170 QE embroidery unit work
Electronics fail eventually. It is a bummer because I bet you love your old Bernie. Electronics are nothing for the novice to mess with unless they have loads of component level experience. I would take this to your sewing tech and have them check it out. (maybe get a new one?)
Jul 21, 2014 | Bernina Artista 170
Artista 165 embroidery unit will not communicate with my sewing machine.
Did it ever work ? Have you had the firmware updated in the machine - if-so, the V4.04 firmware will not communicate with a V3 embroidery unit and you'll have to get them updated to the same version. Failing that, I'm afraid one of them has a fault on the serial interface. Note also that a 165 sewing machine will not work with a 180/185 embroidery unit because the earlier unit has a 2MB memory internally, whereas the later unit has a plug-in 4MB memory.
Feb 09, 2012 | Bernina Artista 180
My embroidery module is not recognised
Is the firmware at the same version in the sewing machine and in the embroidery module ... if not, it wont work. Have the two worked together before, or have you just obtained the EMB separately from the machine ?
Nov 22, 2011 | Bernina Artista 170
I have Bernina Artista embroidery software version 3. I have a laptop with windows xp2 on it. I have downloaded all the updates but It still won't recognize the security dongle. What can I do. The...
Not sure, but I believe version 5 works on XP.
Perhaps this will help:
https://www.bernina.com/en-US/Support-US/Software/BERNINA-Software-Compatibility/Bernina-Software-Compatibility
Feb 20, 2018 | Bernina Artista 170
I am looking for a video or preferably a person who can give me a couple of intro lessons on the embroidery function on the Bernina artista 180. I have been using it for sewing but have been intimdated by...
I'm selling Bernina Artista instruction DVDs on Ebay, one is only for the embroidery part, which teaches very well how to do it. It is for the models 165, 170 and 180.
Jan 26, 2010 | Bernina Artista 180
How do I get patterns from the embroidery CD onto the machine. I have artista v3 and artlikn v4 but I dont know how to use the software with the CD of Latte Quilt
Thank you - but I cannot afford to pay your rates - I went to a local sewing machine shop and got the advise for free.
Sep 30, 2009 | Bernina Artista 170
Trying to connect a Bernina 165 to a Dell computer running Windows XP Pro in order to use machine embroidery. All of the four ports (COM 1, 2, 3 or 4) say the port is engaged. Previously, with an older...
Please check the Bernina website software upgrades for a solution. I use XP Home and have no problem but there was a software upgrade download for my Artlink version and also for the security key for the Bernina Designer 4.0 to install to make it work.
Aug 12, 2009 | Bernina Artista 170
Sewing Machines Logo
93 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Wayne Buss
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
