Question about HP Pavilion dv9000z Notebook
Hp laptop webcam
Hi could u please tell me how to switch my webcam back to my media centre and msn.it was working fine until i used it 4 skype and now it wont do anything else.i hope you could help
  • Studley33 Apr 07, 2008
    on msn when using messenger my laptop cannot detect webcam and i'm stuck, can anyone help with this but you will have to use laymen's terms as not exactly bill gates!
  • hayat167 Nov 30, 2008
    i have a problem in my webcam laptop it were working but i had an virus which attacked my laptop and i desinstalled the hp webcam now i want to know how i will work it? or how to install it in order to use it?, could you please help me to find a solution or give me the driver of hp pavilion dv9000
    New Friend:
    Problem Solver:
  • 10 Answers
Hi Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
Posted on Mar 17, 2009
Please recover for me the dell intel (R) pentium (R) Dual cpu [email protected] Ghz webcam centre or its software
Posted on Nov 22, 2008
Verify msn seetings
Posted on Mar 31, 2008
SOURCE:
Webcam
You both have to be in the same program to use your webcams.
You cannot hear her msn - this is probably a failing on her set up (mic)
She may have a laptop with a built in mic and she needs to nominate her webcam mic as default so that msn/skype software can locate it.
I suggest you both follow these instructions
Audio
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to MSN
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Configure to Skype
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
May 07, 2010 | Logitech Webcam
My HP Pavilion Entertainment webcam issues
First uninstall the drivers and then download the latest bios update for your notebook from hp.com and then restart the computer.... then install the latest updated drivers for webcam from hp.com and check this will surely work.
If not then check for quickplay driver update too.
Another thing open task manager and then go to processes and check wethere you can find the webcam running or not if yes then right click and end the task , also check for the programs that might use webcam like if you have installed yahoo or skype messenger end the program task too.
Apr 10, 2010 | HP Pavilion dv9000z Notebook
HP elitebook 6930p webcam not working with Skype> Webcam version 1.0.021.0507 Skype version 4.1.0.179
did you try to use web cam with another software like msn and see if it is working or not , if yes try to make skype identify web cam again by going to tools menu then options then choose vedio settings it will identify your cam automatically
by the way i love elitebook its amazing piece
Feb 23, 2010 | HP EliteBook 6930p Notebook PC
Hi ihave an acer aspire 5600 .My webcam works with other aplications but not on skype and msn.Could you please help me?
Before you can use your webcam in any chat program you have to configure it to that program
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
WINDOWS LIVE MESSENGER ( MSN)
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Feb 09, 2010 | Logitech Quickcam Chat Webcam
Hp Pavilion: Webcam not working
It sounds like some files are corrupted. Have you checked you device manager? Is there any read or yellow alert in it? Feel free to visit digitalsupporttech for getting help.
Aug 25, 2009 | Computers & Internet
My webcam does not work on msn
first you need to know that if you used xp ...and upgraded to vista ...you need to find a compatible driver for your web cam too ...if your web cam used to work just fine on vista ...and its just the msn issue ...just reinstall the latest MSN messenger and it should be enough ...also verify the proxy servers on the messenger preferences..and set 'em to fit the kinda conexion you use...
but I suspect a problem with the program settings ...so the easy way is just to install the latest messenger(MSN) available for vista ...and it will be ok
May 17, 2009 | Logitech QuickCam Pro 5000 Webcam
Dell webcam manager working with msn messenger?
if you have the webcam center opened along with with msn then it wont work on either one of them.
you can try these steps tp check if it works for you or not.
1)look for the web cam center system tray icon and right click on it if its there and select exit
and as u said u cant see you self in web cam console --- in webcam console you can only see your self under the doodling tab and only of your webcam is working at that i.e
either you have the webcam center opened or any other messenger or software which turns on your cam then only ull be able to view your cam in webcam console alongside.
Apr 28, 2009 | Dell XPS M1530 Laptop
HP zd6000 Laptop. Need a webcam software
Hi!
You can use the webcam with a program like MSN messenger or Skype. If you want to record stuff, you should look into http://webcamrecorder.com/ or google for any webcam recording software.
Good luck and have fun with the webcam!
Jan 05, 2009 | Computers & Internet
Using a webcam
Yes. You need to use the same program in order to talk with each other. Also, in my experiences with webcam setup and the different program carriers to use for best picture quality, I use Skype. I tried AOL, Yahoo etc. and Skype worked the best. You can have the best webcam on the market, but if you don't have a good carrier, the picture quality and sound can still be affected. Since your friend already has MSN, try that yourself and see if it works out for you. Good luck!
Oct 25, 2008 | Acer Aspire 5610-4648 Notebook
Webcam and Live Messenger
I can use the webcam on Skype but when I close Skype and open Instant Messenger I get a message that the webcam is unplugged or being used by another application.
Oct 28, 2006 | Labtec 961307-0914 Webcam
HP Pavilion dv9000z Notebook Logo
190 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
