Question about Refrigerators
Ge refrigerator Our fridge is not keeping everything cold anymore and now the ice is beginning to melt. Any ideas why?
  • 55 Answers
If the unit is old, the refrigerant may need a recharge or the compressor seals may have worn out. If the latter, most people say to buy new unit rather than repair. I suggest getting a service call to get it diagnosed. Good luck!
Posted on Mar 31, 2008
LG LSC26905TT refrigerator not freezing. Everything is melting in the freezer and fridge.. Lights are on, but no cold air is coming.
Remove all items from the fridge and keep open the fridge doors for atleast 2 days and that will remove all the frosted ice on the evaporator(which can't be seen) and shall work fine after two days.
Feb 26, 2014 | LG LSC26905TT Side by Side Refrigerator
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
Driping water into food cooling section.
The drain that carries the water from the freezer to the evap tray is plugged and filling the space between fridge and freezer up with water and then soon it won't be cold in the fridge anymore as it will block the flow of air from the fridge to the freezer. Locate the drain in back of the fridge or inside compartment under freezer and unplug. Should actually unplug fridge overnight to let ice melt in between levels.
Jul 19, 2011 | GE Refrigerators
My ge side by side fridge is not working properly please help me. the freezer side does not freeze anymore it's about as cold as the fridge side what can i do and what is wrong
Check the inside back lower wall inside the freezer. If it has ice built up on it, you will most likely have a defrost problem. This will most likely be a bad heater. You can remove the panel and use a hair dryer to melt ice. The heater is wrapped around the coil inside.
Nov 17, 2009 | GE Refrigerators
Bottom of freezeer and fridge are cold, but top areas aren't?
you have defrost problem or check see if condenser fan working
Apr 07, 2009 | GE Refrigerators
GE fridge GSH22KGMA not getting cold
you need to replace the gasket on the unit . its letting in too much moisture.. the drain line may also be clogged up and holding water in the drain pan. take a piece of wire and clear the drain then poutr hot water and baking soda down it witrh a turkey baster.
Apr 05, 2009 | Refrigerators
GSS22KGMC WW side-by-side refridgerator not cold anymore
I have no idea to this day, what caused the complete lack of cooling in my freezer and refridgerator. However, it seems to be working fine now. All I did was turn the compressor and fan totally off, let it rest for a few minutes, and then turn it back on. It seems to have "re-booted the system, and now everything is working normally. The ice-maker is once again making ice! It has been three days or so now, and so far, so good!
Dec 25, 2008 | GE PSS26SHRSS Side by Side Refrigerator
GE Fridge/Freezer Having to turn temp up just to keep it cold
From your comment. It's not that you have to defrost the parts, that's what they're called. "defrost timer", "defrost t-stat" and "heat element". Defrosting the whole fridge for a few days actually will clear the ice blockage if that's it but it will return in a couple weeks if the "defrost cycle" isn't doing its thing. A fridge typically goes into some form of "defrost cycle" to keep it "frost free". As an example, every 12 hours the compressor turns off and the evap. fan turns off then a heat element turns on to melt the light coating of ice on the "cooling coils". Once about 1/2 hour goes by the heating turns off and the cooling turns back on again. This repeats over and over to keep the ice from building up too much. If that cycle is broken, the ice will build and build till the whole coil is a block of ice. Then the air can't flow around it to provide cold air for the whole unit. It acts basically like putting a large block of ice in the freezer and keeping the doors closed... without a fan to move the cold air only the very lower portion of the freezer is cold, the rest is warm.
Dec 30, 2006 | GE GTH18KBR Top Freezer Refrigerator
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
