Question about Kenmore 64282 Convection/Microwave Oven
Turntable won't turn anymore
We took off the plate and cleaned underneath but that wasn't the problem. It will turn by hand, but not when the microwave is running.
  • bananacake Apr 01, 2008
    The turntable isn't working on Kenmore Elite Convection/Microwave model number 721.642823
  • 5,911 Answers
The turntable has a drive motor which is located behind the panel that covers the BOTTOM of the oven. It could be that this small drive motor has failed. Replacing it should be simple and doesn't cost much. If the oven is mounted, you can leave it in place in most cases and just remove the bottom panel. Make sure the unit is UNPLUGGED before servicing, however. Please post back with your complete model number (located around the door opening) so I can be sure. I'm having a hard time locating any parts info and want to make sure I give you the right advice.
Posted on Mar 31, 2008
  • Jeff Rockwell
    Jeff Rockwell Apr 01, 2008
    The part is available at searspartsdirect.com. Type in your COMPLETE model number (there are two models listed) and look under the "OVEN CAVITY PARTS" index for item #3009. The motor is listed as part #2B72754E and lists at $23.49. I hope this helps you.
  • 100 Answers
The motor is also available from www.microwaveglasstrays.com
Posted on Jun 30, 2008
Turn table doesn't working on my microwave anymore
The turntable is driven by a small electric motor mounted underneath your microwave oven. The motor may have failed. The motor is accessible from underneath the unit and usually a cover plate has to be removed to gain access
Oct 06, 2013 | Microwave Ovens
How to remove the turntable plate
At the base of the spindle of the turntable is a c-clip. Use a table knife or flat screwdriver and needle-nosed pliers to carefully remove it. The turntable can be lifted off. Take care to not damage the belt underneath, if a belt-drive turntable.
If luck is with you, all it needs is a thorough cleaning.
Jan 17, 2013 | Microwave Ovens
A number of days ago we put two plates of food in the microwave to reheat them. There was a snap, crackle, pop noise. We checked to see there was no metal object in the unit....there wasn't ...we know...
Are you sure the plates were Microwave oven safe? Some dishes have metal in the colors of the design. A snap, crackle, pop noise normally means there is metal present in the oven.
Jun 05, 2011 | Microwave Ovens
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
Turntable does not spin
There is a coupler that connects the turntable motor to the plate. It's the square or odd shaped object in the center of the microwave after the turntable is removed. You can try to pull it up from the microwave to see if it is broken or if it will turn by hand, it is probably broken.
Jun 21, 2010 | Smeg FME24X Microwave Oven
My turntable stopped rotating on my GEJVM1490 for no reason. everything else works fine, any suggestions?
There is a small motor underneath the microwave which turns the plate or turntable around.
If this is faulty then you will need a service agent to repair it.
Jun 17, 2009 | GE JVM1440 Microwave Oven
Em-s3577s uk 2 wont turn
Remove the turntable plate and check the motor coupling gears underneath, if motor coupling is fine, then replace the turntable motor.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 19, 2009 | Sanyo Microwave Ovens
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
Microwave turntable on strike.
motor underneath - belt broke or motor burned out.
Dec 28, 2007 | Jenn-Air JMC9158AA Convection Microwave...
Kenmore Elite 66469 Turntable "Clunking" Sound
Either the coupler or the turntable support is bad.
You can find an exploded view by entering your FULL model number (3 digits, a dot, then 8 digits) here: http://www3.sears.com (the 3 is correct)
Dec 08, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Kenmore 64282 Convection/Microwave Oven Logo
109 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
