Stored Data Lock-Up In A Single Contacts File
Here's A Problem You Probably Don't See Much Of If Ever...
Concerning My Sharp ZR-5800 Zaurus pda > My data locked-up on me a week ago...
More correctly & specifically, I am locked-out of my contacts file > Not sure why since I still have un-used memory > However, my colleague mentioned that I may have too much data stored into a single file, the contacts file, causing a data lock-up...
Did try re-booting by removing & replacing the batteries, but that didn't work > Of course I could re-set the unit but that would delete all stored data.
Does anyone out there know a trick or code to un-locking this unit???
This pda unit is not locked-up due to a secrete location or password...
Any Help Or Assistance Would Be Greatly Appreciated.........
New User w/ Nick Name "OOP-DAA"
  • 7 more comments
  • OOP-DAA Apr 15, 2008
    Would Lose All My Valuable Data If I Used A Hard Re-Set...
    Any Other Options > MikeK > Oop-Daa...
    Will Try Your Solution This Evening > Hope It Works > Will Accept Solution If It Does...
    Oop-Daa.......
  • OOP-DAA Apr 16, 2008
    Tried Your Solution 3 Times > Sorry But It
    Did Not Work...
    Oop-Daa...
  • OOP-DAA Apr 21, 2008
    Unlocking Code Not Stated By Device > Just Trying To Figure Out How To Unlock Data In My Contact File > Any Ideas???
    Thanks, Oop-Daa.......
    Tried Hard Reset & Tried Again...
    Unfortunately Data Still Locked Up...
    Any Other Ideas???
    Tried Removing Batteries & Memory Card For An Hour As Well As Resetting The Unit Both W/ and W/O Memory Card Installed...
    Also Tried A Hard Reset...
    Contact File Data Still Locked-Up > Cannot Gain Access To Contact File...
    Looking For More Options From The Experts...
    Thanks, OOP-DAA.......
  • OOP-DAA Apr 24, 2008
    Contacts Are Stored On The Units Internal Memory > The Memory Card Is Non-Operational > Just Used To Keep The Dust Out Of The Unit Since I Lost The Original Blank Card That Came w/ The Unit...
    Oop-Daa.......
  • OOP-DAA Apr 29, 2008
    When I Try To Access My PDA Contact File From
    Start-Up, I Just Get The Sharp Logo Screen.
    The Unit Stays Stuck On This Screen For About
    2-3 Minutes, Then It Clicks Back To Start-Up Mode w/ No Access To Contact Files; Access To
    All Other Files OK...
  • OOP-DAA Apr 30, 2008
    Good Morning Ginko,
    My Gut Feeling Is That You May Be Right Concerning Possible Defective Or Corrupted Data Storage In My Contact File > A Close Colleague Of Mine Reflected The Same Conclusion...
    Did Send Away For Proper Connection Cable Kit
    From PDA Unit To PC > Will Try Data Recovery Procedure When It Arrives...
    In Any Event, Believing This To Be True, I Am
    Accepting Your Solution Which By-The-Way; You
    Were The Only Fix-Ya Expert To Come To Such A Conclusion...
    Cordially, MikeK aka Oop-Daa...
    PS: When I Receive The Connection Cables, To
    Your Knowledge, Is There Any Specific Format To Recover "Corrupted Data" By Way Of PC...
    They Say "Unique Problems Require Unique Solutions" And I Really Appreciate All The Concern & Technical Feedback That You Sent Me
    Related To My Problem As You Do Seem To Be The True "Guru Master"...
    Thanks Again.........
    Genius:
  • 1,027 Answers
If you can attach device to a computer, you might want to try RECUVA, save all data to some where else on your computer, hard reset, and move data back file by file.
Posted on Apr 21, 2008
  • 19,396 Answers
It is quite difficult to understand the problem, as you keep rejecting all answers immediately. In this way no expert is going to follow you in troubleshooting your problem. Many expert will just post a single sentence etc.
In all the confusion generated by your misuse of Fixya I understood you have passworded unrecoverable Data (lost password) or corrupt Data. If this is the situation what you need to do is saving a backup of your contacts into a computer, reset the machine to factory as posted, then restore all your data.
A reset had already been suggested, I am sure you would have got to this same point dialoguing whith experts proposing this solution.
Refuse what you want but this is what you need to do.Save a backup, restore to factory, restore your files from backup.
Here is the manual
Follow instruction from manual to connect to computer and save your data. You can also connect wirelessly.
I hope you find a better way to interact proficiently with experts next time you use Fixya.
Best regards
  • 3 more comments
  • Ginko
    Ginko Apr 21, 2008
    One last thing, depending on which data you cannot access, it can also be a faulty flash memory card.
    Read the card using a computer with card reader (or use external usb card reader) and test it.
  • Ginko
    Ginko Apr 29, 2008
    Did you connect to computer to do backup as suggested?
  • Ginko
    Ginko Apr 29, 2008
    Data is not locked, standing on your description your PDA is freezing up when you try acessing contacts, that means data is defective, not locked. You need to connect to PC, is only possible way to recover your data from home. Did you try connecting to computer, and seeing if computer can backup contacts?
  • Ginko
    Ginko Apr 30, 2008
    A defective static memory, like the one inside your PDA works similarly to a defective hard disk, depends on where is the problem, usually if you cannot even see data you will not be able to recover it without using special tools like this
    File Recovery SoftwareAnd even using the software usually you cannt recover data or have only a partial recover.
    If the lost data is valuable enough, and you do not have a copy, a way to proceed may be by contacting a data recovery company in your area, like this one here: http://www.datarecoverycorp.co.uk/%3Fsou...">Data Recovery In UK.
    Try finding one that apply no fix no fee principle. The do not always work.
  • Ginko
    Ginko Apr 30, 2008
    First thing to do: try using cable and only software provided for connecting Sharp PDA to computer without any additional software. If it works you will have a working backup of your PDA data on your pc.
    Genius:
  • 3,422 Answers
Correct me if i am wrong.All you need is the important contact detail files and other things from your memory card.Then why don't you use this memory card on your laptop.If you have a card reader reader on your laptop insert the card in it and transfer the file using THIS SOFTWARE
Then once you get them back on your laptop just format your card and transfer the contact files on it again.
Well this is the only solution i believe.If you still face the problem you will have to contact the customer support of your product about this problem.
Goodluck,
Please don't forget to rate the solution
    Master:
  • 788 Answers
Are you contacts stored on the memory card or in the unit's internal memory?
  • Dean Joly
    Dean Joly Apr 25, 2008
    You should be able to explore the file structue of the PDA from Windows when it is connected to a PC. I beleive you can explore the PDA in ActiveSync. Browse through the stucture, you should be able to find your contacts file(s), not sure exactly where you would find it I don't have a PDA with me to check.
    Once you find to file, you should be able to see if it's set to "read only" or if anything else looks funny about the file.
    What exactly comes up on the screen when you try to access your contacts? What kind of error or indication do you get that tells you your file it too big or locked up?
  • Dean Joly
    Dean Joly Apr 29, 2008
    Try to explore the PDA from Windows, it's your best bet.
    Genius:
  • 1,665 Answers
You must try a hard reset and try again.
Posted on Apr 14, 2008
    Master:
  • 377 Answers
A unlocking code... Which locking code did your unit say's to be input..
Thanks
    Genius:
  • 1,447 Answers
Try looking on this link if you can find anything helpful.
http://www.sharpusa.com/files/org_man_ZR5700_5800.pdf
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 14, 2008
    Try turning off unit, remove battery and memory card then after 30mins-an hour reinstall memory card and battery. turn unit back on.
    Try resetting unit as well without any card/ use a different card while resetting the unit.
6ya staff
SOURCE:
I HAD a Sharp Zaurus 5800 PDA. I also had the Zaurus address book backed up in Windows XP. I upgraded to 8.1 but can't find the address book. The Rupplynx 6.2 CD I have doesn't work with 8.1. I know t
Hi
Was the backed up version of the address book openable by WinXP or one of its programmes? If it was you may be able to run WinXP as a virtual machine on Win8.1, otherwise you need to find a programme which will open the address book file or import it in a form that makes sense. This may not be easy !
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 03, 2014 | Sharp Zaurus ZR-5800
I lost my old Sharp Zaurus ZR 3000 K-PDA data when I changed its memory battery. The Zaurus software disks (Win. 95) were useless after I moved up to WinXp, and now are lost. Any idea how could I transfer...
It was ages ago I used my ZR5800. Looks like the 3000.
I only have the device and some old flash cards. Most of my data was coppied to the flashcards. I lost my manual, but I'm sure you could connect by infra red to a laptop. or another IR device.
The flashcards worked in the old laptops, so if you have an old laptop, check if you can put the flashcards in and if you can connect via IR.
Oct 30, 2013 | Sharp Zaurus Computers & Internet
ZR-5800 won't restart
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Aug 10, 2012 | Sharp Zaurus ZR-5800
Sharp zaurus zr-5000 stopped working. Any way to get my backup flashcard (FL02M-20-11138-XX 15095) to read to anything?
I have lost all comm ports for exchanging info to and from my Zaurus 5000. It says my ports are being used by my mouse which is not true.
Anyone have any ideas on how to retrieve ports?
Ted
Oct 20, 2010 | Sharp Zaurus ZR-5700
I installed replacement batteries with the polarity reversed. Since then unit does not display the Contact file, but all other functions (activities, data files, etc.) seem unimpaired. Any ideas? I...
Hi, well the reason this has happened is that these contacts are stored in battery backed up NVRAM, now this RAM is very sensitive to polarity reversal, and also due to the way it works, doesn't have polarity reversal protection, on that circuit. So when you reversed those batteries even though the reverse polarity protection saved the Unit as a whole, the NVRAM would have been destroyed or wiped at best. These is no real way of replacing this NVRAM, I guess you could send it back to the factory though and ask for a "Quote" with view to the repair.
Sep 14, 2010 | Sharp Zaurus ZR-5700
How to transfer Sharp Zaurus 5800 data to mac osx leopard?
Hi you can use Bluetooth, or if you have the cable to connect from the Zaurus to the computer you have make the connection and make sure the computer recognize the Zaurus before you can do any transfer.
Jul 28, 2010 | Sharp Zaurus ZR-5700
Sharp wizard. Batteries dead. can you retrieve information???
Depends. The Wizards had backup battery. As long as it is still good, then your data is safe. if you saved / copied / made backups to the compact flash card (Type 1 option) as well, then you have a copy there that you might be able to use in a computer. Sharp used a different, not quite proprietary, format for storing data though. You may be able to see the data on the computer, but won't be able to open the individual files.
If your backup battery is dead, and the main batteries are dead, and you don't have backups on CF, then your data is likely gone.
Jun 23, 2010 | Sharp Zaurus ZR-5800
My Zr-500 will not turn on. any ideas?
replaced the batteries. first things first
Nov 17, 2009 | Sharp Zaurus ZR-5800
Memory back up card for Zaurus 5800
My Zaurus 5800 shuts itself off even when on AC current. Never did this before. Do you know why?
Jun 05, 2009 | Sharp Zaurus ZR-5800
Open Questions:
Crypto phone Number 1855=536=5666 Crypto phone Number Crypto is one of the biggest companies in the world which is providing its services. It has invested in various functions and can provide the best when we compare to others. So if you are interested in having the services, then you should not think twice. As they even offer you the benefit of having the help from the Crypto email Toll free Number. Once the person has those, then the user will be able to get the help from the user in a way which is going to make his experience a euphoric one. So dial the number whenever you are facing the problem. Crypto support number When you are using the Crypto for the cable, telecommunication, internet services or anything, then you will find it to be the best. The user will find that there is no other option when it comes to the quality of the services they provide. But even after that, there are some problems which are needed to be tackled. For that, the user can dial the Crypto support number and ask for the help. Once you dial the Crypto customer support number, you come in contact with a team of experts at the Crypto customer service. They will be able to help out the user with any situation in which they are stuck. So whenever the user feels that he or she is stuck, then there is no need to make any rash decisions. As the team on the Crypto support phone number will help you with that simply and quickly. This is Crypto's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Crypto agent. Features of Crypto support number A person can face difficulty while using technology anywhere and anytime. But this does not mean that you will leave that application or make any rash decisions. As you or any user will be able to get the help from the Crypto customer support phone number. Here are some of the features of customer service: The Crypto customer support phone number which you will be using to contact them is available 24/7. So the user will be able to get the help whenever they are facing the problem. There is no need for the user to find the solution his or her own and waste time. AS the Crypto customer service will be doing all that for you. The only thing that will be required from you is to dial the number and apply the solution provided by them. When you want the help for the service for which you have paid, then you do not want to spend any more money. For this Crypto provides you the facility of Crypto support phone number. The number which you or user will be using is toll-free. So they will be able to get help from an expert without paying any money. There is no waiting time for the call the customer is making for the help. So the only time that you have to wait to get in touch for the help is a few seconds. And after that, you will be able to get the help that you want. Problem Faced Various problems can be face by the user while using the Crypto. Here are some of the issues that you are going to face when you are using the application: The user might be having trouble with the connectivity of the internet services. There might be questions regarding the plan the user is using, or how can he or she change it? Might be some channels are missing. The list can go on, but there is no need for the user to worry about. As the user can always get the solution to the problem by contacting the Crypto Customer support number team.
Oct 22, 2019 | HIS Computers & Internet
Computers & Internet Logo
57 people viewed this question
Ekse
Marvin
Marvin
