Question about GE WDSR2080D Top Load Washer
GE Top load washing machine stop and stars during spin cycle
My top loeading Ge washing machine stopped running the other day. I un plugged it and it will now run. During the spin cycle it will run for 5 seconds then stop. 1 second later it will start again. It does this repeatedly. Any help appreciated.
  • 1 more comment
  • msguy381 Apr 19, 2008
    My washer started doing the exact same thing 3 weeks ago. Mine will work perfectly and then stop. No sounds from the motor at all. After it sits for a few hours it will work perfectly again... washes fine then starts to spin FOR A FEW SECONDS then quits. It started this about 3 weeks ago then started working perfectly for about 2 weeks... now it is on the blink again. One more thing I have noticed is that if you leave it on the timer will get to the spin cycle and drain all of the water out as if the system is actually about to spin. Once the timer gets to the spin cycle it goes silent completely. No hum or anything from the motor. just like it is turned off. ANY HELP WOULD BE MUCH APPRECIATED! THANKS.
    SYNOPSIS:
    1 FILLS NORMALLY
    2 WASHES FOR A FEW MINUTES
    3 DRAINS NORMALLY
    4 SOMETIMES SPINS FOR A FEW SECONDS THEN CLICKS ON AND OFF BETWEEN TRYING TO START AND STOP... THE WASHER DOES SPIN WHEN IT ATTEMPTS.. AND SOUNDS NORMAL.
  • GE john Apr 19, 2008
    My GE washer does the same thing.It washes fine up to the spin cycle.Then spins 5 seconds stops spins 5 seconds stops until timer shuts it off.Im sure it is the motor over load switch in the moter shutting it off.But is the motor bad or the tub hard for the motor to turn causing motor to shut off. model # wpsr3100woww. Does anyone know anything about this problem Thanks, John
  • Anonymous Sep 13, 2008
    how long before u give an answer
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
Mine had the same problem.
I removed the front door, disconnected the two wires from the water pump and put a voltimeter on the wires. In spin cycle it measured 127 volts, as expected (the pump is that voltage)
Next... prepare to get messy:
Try to empty the top drum as much as you can before proceeding;
Mine had about 1 or 2 gallons left inside that I could not remove;
The water pump will have 2 big hoses attached to it: one coming from the bottom of the drum and another that is the discharge tube;
Release both springs from those hoses and to minimize the mess;
wrap a big trash bag around the water pump and the hoses, then remove the hoses. If water comes pouring from the drum-bottom-hose as expected, the clog is not there.
If you can have someone to help to hold the bag in place, that will be great.
Once it stops dripping... remove the water pump out.
You will also check the discharge tube/hose. It should, of course, flow freely;
When I took the pump out, I could immediately see the cause... lots of pillow stuffing (grrr... doggone children !)
Anyway, the channel is pretty large and there is no filter whatsoever, but nevertheless, I took our the 3 screews to remove the clog.
When you separate the parts, make sure the pump turns ok, ie., the shaft is not locked or grinding or rough.
It is expected to have a certain resistance caused by the magnet inside but should run smooth. If you find that it won't turn at all,
time to replace it.
Wash all just to clean any rest of debris and put them back.
Install the pump back in the reverse order and it will work again.
Mine is 6 years old and still runs fine (after that clog was removed :-)
Posted on Dec 30, 2008
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
The water runs during the spin cycle. The clothes
Does the water run through the ENTIRE spin cycle? There is a period where the water will run during the spin; This is called, the "Final Rinse". But it usually only runs for about 10 seconds then stops.
Dec 22, 2009 | Washing Machines
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
My GE Wizard Washer will agitate or spin for a very short time.
replace the transmission. this job is better done after a few dozen bottle of your favorite whiskey. Check the timer controls to ensure timer is advancing properly. tranny's are notorious on ge's for this sort of problem as well as inner basket drive blocks coming loose. ge makes alot of great appliances, this just happens to be one of them that isn't. i trust their jet engines too, although hard to work on them from 30,000ft.
Jul 02, 2009 | GE WBSR3140DW Top Load Washer
No spin or agatae
Unplug machine. Change load type to medium. Clean door sensor. Set knob to drain and spin. Plug machine back in to powr. Open and close door 10 times in 15 seconds. Pull knob to activate drain and spin.
Mar 19, 2009 | General Electric WHDSR316G Top Load Washer
How do you reset the washer?
I have a GE WBSR3000GWS Model and it stopped spinning at one point as well. My service guy came out and did the procedure below and reset it with in minutes.
How to Reset your GE Washer :
1. Turn the dial like your going to wash a load but do not pull the knob.
2. Unplug the washer from the wall and wait for 30 seconds.
3. Plug the washer back into the wall.
4. Lift the lid 5 times to at least 6 inches high. Open/Close within 15 secs.
5. Pause… You should here a click. If you do not, then repeat 1 – 5 again.
6. Insert a towel or garment into the washer and then pull knob to start the wash cycle.
7. Check the wash cycle to make sure the washer is agiating and spinning during its cycle.
GE Answer Center : 1-800-626-2000 opt 3 - for more information
Lale
Jun 20, 2008 | GE WBSR3140DW Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
GE WDSR2080D Top Load Washer Logo
4,002 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
