Question about Sony KP-61HS30 TV
No signal chris, thanks for the help. now a question. does the tuner have an adjustment or do i need to replace it? also is tuner part of intergreated circuit or is it a smaller servicable card? thanks for help. danny
  • 129 Answers
Good day.
Apologies for the long period I was not able to reply. A tuner is like a block with terminals. Voltages to consider here is the data - 5 volts, supply - 30 v and 12 input voltage. Try to check for abnormalities along these voltages and if confirmed they are present, replace the tuner.
regards,
chris
Posted on Apr 06, 2008
My tvs say no signal in my RV. TV comes on I adjust antenna but still no signal. Help
Are you trying to look at an analog signal? There aren't any left. If your TV doesn't have a digital tuner in it, you'll need a converter box. If it has a digital tuner, do a channel scan for digital only stations.
Jan 21, 2017 | Televison & Video
I have a Samsung 46 LCD, model LN46A550P3F, that about six months ago had the well known problem of cycling off and on, with the clicking noise, and making occasional LOUD static noises with a distorted...
Power supply board u fixed before was good,but the tv main Tuner signal board it was working on it last leg.Distorted picture screen loud static noises are the indications of the tv main Tuner signal board are not regulating signals of all of those ICS output on the tv main Tuner signal board it is dying and now it is dead.Don't change the T-CON bord it is good.Tries Shopjimmy.com,Ebay.com to buy a whole refurbish tv main Tuner signal board for the replacement.
Aug 01, 2011 | Samsung LN46A650 46 in. LCD HDTV
Trouble adjusting the color.. NO reds and can't seem to dial them in. Thanks, Chris
Recheck ur tv incomming broadcasting signal cable wire like hook it up to another tv,see if another tv is getting the red color,if not the incomming signal wire is the problems.If it the tv problems,than the tv Tuner signal board is dying,require changing the tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Apr 17, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
My kdl55nx810 screen is blinking. While watching TV, the screen will go black for about 2 seconds, then come back on. It appears to happen intermittenly, every 15, 30, or 60 seconds. TV was working fine,...
This problems,it can't be repair.The tv Tuner signal board is problems and the the causes.The tv Tuner signal board have intermittent problems.That the board,where the tv incomming signal cable plug into it.Tv is still useable wright?Use it the tv as is.Or only way to repair it is to do a replacement of the whole tv Tuner signal board to fix this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Mar 15, 2011 | Sony Kdl-55hx701 54.6 in. HDTV LCD TV
Hi guys, I have an AOC L26W861 when i power it on all I get is white light and no sound , Anyone have an idea what I should do ??? This is the first flat screen lcd I have worked on. any advice would help,...
The tv Tuner signal board is the problems and the causes.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 17, 2010 | Televison & Video
I have no picture on my Sanyo Dp32746 LCD tv, the audio works fine. I replaced the backlight inverter board, but still no picture. Tried the reset button on the remote, can not see the main menu to try to...
U replaced the 1 or 2 LCD inverter long boards,still the same problems.Sorry,this is a rare problems,but it seem the Tuner board is the problems.Replaced the Tuner board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 08, 2010 | Sanyo DP32746 32 in. LCD Television
RCA P52927 sound is static
Need adjust coil sound ( little metal beside Big IC or between tuner and IC). Turn a little right and left ( be sure leave same position) don't play with this coil too much, will mess up video signal , some times tuner need be re solder. I hope this will help you Thank you!!!
Jun 30, 2008 | RCA P52926 52" Rear Projection Television
Digital
Good day,
Yes, it has a digital tuner. It is functioning based on the command set by the buttons or signal/command from remocon.
chris
Mar 16, 2008 | Sony KV-27FS13 27" TV
Signal out of range?
Using your CRT, open the properties of the video adapter. Look for the refresh rate and set it to 60Hz. This should fix your problem.
Hope this helps, and please rate my advice, good OR bad.
Thanks, and good luck!
Feb 02, 2008 | Balance CM2017 17" Monitor
RCA Scenium HDLP 50
YOU HAVE AN INTERNAL TUNER FAILURE IT NEEDS TO BE REPLACED
Jan 06, 2008 | Televison & Video
Sony KP-61HS30 TV Logo
46 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
