Question about SanDisk Sansa e200 MP3 Player
How to get the music folder back
I have a really weird problem. I just connected my e250 to my pc in order to delete all of my songs and there's a weird problem, there's no MUSIC folder.
So I create one by myself named "music" and my pc gives me an error saying that a file named music is already on there, but it's obviously not present.
So I switched my USB mode from MSC to MTP and when I connected my device, the music folder showed up and I was able to delete all of my songs.
So how can I bring back the music folder from the USB mode: MSC?
And if I can't, is it better for me to stick with the MTP
    Problem Solver:
  • 5 Answers
Well, your music folder is actually a hidden folder. To make it visible go to computer and then folder options. From there check show hidden folders and files and you should be able to access your music folder.
Posted on Jul 16, 2009
  • 758 Answers
It sounds like your device firmware may have been corrupted..you are not suppose to manually put a my music folder on your device..Now to get the my music folder I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Apr 02, 2008
How do I remove songs from my e250? It says that
1) Connect your e250 to your PC.
2) Open up "My Computer".
3) Look for your e250 in the list under My Computer, then double-click on it.
4) If you see something called "Internal Memory", double-click on that.
5) You should see a folder called "Music" ... double-click on that.
6) You'll find your music under the "Music" folder ... delete it using Windows Explorer.
Jan 29, 2010 | SanDisk Sansa e250 MP3 Player
How do we remove songs from the sansa e250?
Go to My Comp
choose Sansa E250
Click on Tools ,choose Folder Option, Click on the View Tab,
Put a dot on Show Hidden Files and Folder click on Apply then OK.
you will see the Music Folder, double click so you will see all your songs
to delete press the delete key on the keyboard, or right click on the song choose delete.
Good luck
Jan 10, 2009 | SanDisk Sansa e250 MP3 Player
How to remove songs....i dont get it still
hello!
here's how you will delete songs off your Sansa e250
step 1: Go to"MY COMPUTER
Step 2: Find and open the sansa drive
Step 3: Look for the music folder.
NOTE:
If you dont see a music folder you will need to go to the top where it says tools>then >folder options>then click on show hidden files>
Step 4: You should now see the music file. Go into it and simply delete any songs you don't want.
May 08, 2008 | SanDisk Sansa e250 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
Deleting downloaded songs
The users guide is on the CD that came with it, otherwise you can download it from here;
http://sandisk.com/sansa/assets/English/products/e200/e200_userguide_en.pdf
As for deleting the pre-loaded songs, you can manually delete them from the device while its connected to the PC. Go to My Computer>Device Name (e250)>Music Folder then just right click and delete on the items you do not want.
Best of Luck.
Nov 04, 2007 | SanDisk Sansa e250 MP3 Player
How do i delete songs off of my sansa e250?
You can manually delete the music thru My Computer. Just click on the device name, and open the Music folder. If you dont have a Music folder, you need to enable hidden files and folders on your computer. Best of Luck.
Sep 23, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs from Sandisk
Hi. The minimum requirements of your Sansa E250 is Windows XP and above and Windows Media Player 10 and above. If you're using Windows Media Player 10 or above, your Sansa E250 and its contents should appear on the right pane when you click on the "Sync" tab. You can right click on a song and select "Remove". The songs will be erased permanently from the player. If your songs do not appear on Windows Media Player 10 or above, it is possible that your songs may have been saved on another mode. Your Sansa E250 comes in 2 modes: MTP and MSC. Songs saved on one mode will not be seen by the other mode, and vice versa. There are 2 ways to delete songs from your Sansa E250: By browsing the folders containing the songs, or by formatting the player. You can switch modes by navigating your E250's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E250 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E250" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player. I hope this helps. :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
Deleting files from Sansa e250
The only way I know to delete music files or voice or FM recordings, is straight from the User's manual on the CD: 1. Set the e250 to MSC mode. 2. Plug it in to your computer with the USB connector. 3. Open the Sansa e250 drive in My Computer and browse to the MUSIC folder (or RECORD folder)and delete the files there. (That's where you also add music files, by dragging from other explorer windows.) To delete (or add) photo and video files, you have to use the Media Converter, which you install from the disk that came with the e250.
Feb 18, 2007 | SanDisk Sansa e250 MP3 Player
[Sansa e250] Deleted songs and now...
what you really have to do is: 1: Double click my computer 2:Double click Sansa e250 drive 3: Right click on the icon that looks like a disk drive and click format BE SURE TO HAVE BACKUP OF SONGS BEFORE YOU FORMAT!!!
Jan 06, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
127 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
