Question about Metrologic Instruments 9520 Voyager
Voyager 9520 10 digit UPC
I have found the correct application to drop the first "0" in the UPC but I need the correct application to drop the last digit in the UPC. I have downloaded all of the application manuals and software and I still can't figure this out. I just want to be able to scan a 10 digit UPC instead of 12. Please let me know if you can help. Thank you!
  • 661 Answers
The last digit should be a parity Digit (used for error checking)
you may be able to clear this using the settings barcodes in the user manual
Posted on Apr 18, 2008
SOURCE:
I need to find out what this item is at walmart. the upc is 076087800245 Girls Boots
I would call a walmart directly and have them give you the walmart number for those boots, girls boots all seem to have a 9 digit number starting with 552
Mar 07, 2015 | Computers & Internet
UPC code85948500222
Hi. I'm not sure if this will help you, but I found this website:
UPC Database Item Lookup
According to this website:
"Enter the all digits printed on the UPC bar code, including any numbers to the right or left of the bar code itself, even if they don't line up with the main row of numbers. This should be 13 digits for an EAN/UCC-13, 12 digits for a Type A UPC code, or 8 digits for a Type-E (zero-supressed) UPC code. Anything other than 8 or 12 digits is not a UPC code! (And just because it's 8 or 12 digits doesn't mean it is a UPC.) You must enter every digit here.
If you have a barcode scanner that outputs plain numbers, you should be able to use it to enter the UPC number here."
So, apparently you need more digits to complete the bar code #. But if you have the full barcode, you should be able to enter it on the website linked above, and find the image of the frames that you are looking for. I hope this helped. Thanks!
Oct 23, 2014 | Datalogic QuickScan QS6000 Plus Bar Code...
Honeywell
Scan "do not expand ean-8 to ean-13" in your programming guide.
Jan 18, 2013 | Honeywell Voyager 1200g Barcode Scanner...
My scanner reads only12 numbers not 13 numbers from barcode what h do?
Perhaps you should ask for replacements and ask for a bar code scanner who reads 13 numbers because even how many times you try it over and over again if the function of the scanner is limited in reading 12 number the results will be the same..Hope it can Help you.
Jul 02, 2011 | Metrologic Instruments 9520 Voyager
What is the upc?
UPC=Universal Product Code
Wikipedia says:
The UPC encodes 12 decimal digits as SLLLLLLMRRRRRRE, where S (start) and E (end) are the bit pattern 101, M (middle) is the bit pattern 01010 (called guard bars), and each L (left) and R (right) are digits, each one represented by a seven-bit code. This is a total of 95 bits. The bit pattern for each numeral is designed to be as little like the others as possible, and to have no more than four consecutive 1s or 0s in order. Both are for reliability in scanning.
Since S, M, and E all include two bars, and each of the 12 digits of the UPC-A barcode consists of two bars and two spaces, all UPC-A barcodes consist of exactly (3 × 2) + (12 × 2) = 30 bars.
The UPC has only numerals, with no letters or other characters. The first digit L is the prefix. The last digit R is an error correcting check digit, allowing some errors in scanning or manual entry to be detected. UPC data structures are a component of GTINs (Global Trade Item Numbers). All of these data structures follow the global GS1 standards.
Apr 10, 2011 | Nextar MA933A MP3 Player
I need to strip the last character from the barcode when scanned with a Symbol P370 scanner. Is there a procedure for that?
If the barcode is a UPC-A or UPC-E you would scan the Do Not Transmit UPC-A or UPC-E Check Digit barcode from the P370 Product Reference Guide.
If the barcode is something other than a UPC-A or UPC-E the last character can be stripped using Advanced Data Formatting which would require the use of 123Scan. You can download 123Scan from support.symbol.com.
The P370 is NOT supported by the newer 123Scan2.
Jan 21, 2011 | Symbol P370 Wireless Barcode Scanner
How do I disregard the last character on a UPC bar code?
In general you can create an Advanced Data Programming Rule which will say: If you scan an UPC barcode, please send only the first 11 characters of the barcode.
There are programming barcodes in the manual for the scanner or you can use the 123Scan2 application provided at support.symbol.com to create the rule and print out an config sheet.
Aug 26, 2010 | Symbol LS2208 Handheld
I need a code that will unlock my found voyager
The code is the last 4 digits of your phone number
Jul 22, 2009 | LG VOYAGER VX10000 Cellular Phone
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Metrologic Instruments 9520 Voyager Logo
736 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
WatsHVAC
Level 1 Expert
George Etukudo
George Etukudo
Jason E
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
