Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Changing the belt on my GE washer
How do I actually get to the belt on my GE topload washer. I think it may have slipped off or broken. On the spin cycle i can hear it trying to spin with some noise like something is on it but not actually catching.
  • 26 Answers
Take a 3inch plastic putty knife and slip it appx 2 inches from each side between the front panel and the top assy. There are 2 spring clips in this area. If you take a flashlight and look between the panels you can see them. When you pop off the panel it will come forward and lifts off the bottom clips freely. Install it by just setting in the bottom panel and pushing on each top side of the front panel.
Posted on Mar 31, 2008
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
Washer wont spin
You may have some small piece of clothing stuck in the water pump. Pull clothes out, empty water out, turn over and remove pump and check for obstructions. If nothing in there see if it is frozen from moving, if not belt may be loose by being streched. Replace belt if needed.
Apr 16, 2010 | GE Spacemaker WSLP1100D Top Load Washer
Toploading Hotpoint washer does not spin. Can hear machine attempt to spin but nothing happens? Help!
Sounds like the drive unit has broken or slipped a belt. Remove the front cover of the machine with screws that are on the rear side of the frame and along the top below the controls, the entire front cabinet will pivot out and away from the frame. You can then see the motor and drive unit and access the problem area. It should be pretty apparent. Hope thias helps.
Jul 19, 2009 | Washing Machines
Burning smell and washer will not spin
The buring smell could be coming from the belt, try looking to see if the belt i burnt or broken
Nov 22, 2008 | Whirlpool LSN1000LW Top Load Washer
Frigidaire washer topload, Agitates but the tub spins
yes the problem parts of the transmission if your going to keep it have new transmission installed
Jan 17, 2008 | Frigidaire ATF6000ES Front Load Washer
LG Toploader Wash cycle won't work
check for the water seal first if it is leaking! if it does, then it might just be the one causing slipping.
Nov 13, 2007 | LG WFT1071TP Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal De
