Question about Compaq Evo N610C Notebook
Battery problem or fan?
My compaq simply turned off one day and will not turn back on. while plugged in it makes this constant beeping noise. what can i do?
    Sergeant:
  • 349 Answers
If the laptop posts (power on self test)
and you see stuff on the screen, no matter how short , do the following: (this checks for a software problem)when booting up press F8 and when you get to the menu, boot up into safe mode,
then restore the pc back to a date before you had the problem, and/or remove any program you installed prior to you having the problem,
if that don't work Try a bootable anti virus disc, use it to check for any viruses ,
if not try a recovery disc, or operating system disc ,
both disc's will try to access the hard drive. if they do not work, (nothing has changed) nothing comes on the screen.
laptop does not post:
(then it is a hardware problem)
try the following first.check battery is seated correctly and that the power pack is functioning,
if the battery has gone flat and the power pack is not working ,the laptop will not start.
Remove any hardware you may have installed prior to you having the problem.
remove the screw(s) holding the cover plate on the back of the laptop where the ram lives and remove the memory sticks,
clean the gold edges both sides, with rubbing alcohol or a pencil eraser, and re-insert them, (not an ink eraser as it will do damage)
swap them around if you have more than one,
try one at a time.
if you only have one, borrow one from a friend or try the ram in your friends laptop ,if that's possible, or
get a friend or family member to download a "memory chip diagnostic's" program such as memcheck 1.70 and boot up of it ,it will check your ram ,if not
take the ram to your local pc shop and ask them to check it for you (they may do that for you)
if you can establish that the ram and power pack is ok, and anti virus and recovery /system disc's do not work,
it may be that the motherboard or the cpu is failing
Generally a dead hard drive would not stop the laptop from posting.
good luck with that and let me know how you get on
Terry
Posted on Apr 01, 2008
1. Microwave noise 2. keyboard and beeping
Make sure oven is plugged into a grounded outlet, and that the outlet is actually grounded.
Although extremely rare, I have seen ovens where insects were walking on the back side of a control panel, and causing problems. Could also just be some sort of electronic failure.
Mar 14, 2016 | In Microwave Ovens
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
HP Compaq 6735s Laptop screen was blank when turned on
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Mar 26, 2012 | Computers & Internet
MY COMPUTER WONT TURN ON AND MAKING A BEEPING NOISE
beep noise indicates that the RAM is not detected.... TURN OFF computer....remove power supply....open the cabinet and remove the RAM.... clean it using a soft non-moist cloth...plug it back.... your computer will start... still if it is not starting, then the RAM might have gone faulty, try to check with other RAM.....
Apr 28, 2010 | Compaq CV 7500 17" CRT Monitor
Compaq cq60 wont start
My first step would be to take the laptop apart again. If it worked after the new fan installation, then can you install the old one (bearing the noise for a bit) and see if it turns on. Then replace the old with the new and if it fails, then perhaps the new fan is grounding your system out.
Good luck
Keep us posted.
-Carlos:
Dec 17, 2009 | Compaq Computers & Internet
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Powering off
Actually, if it is beeping as though the battery is low even while it is plugged in, it is because the battery is no longer any good and is sucking all the power from the wall. You need to purchase a new battery. Until you get a new battery, you can simply remove the battery and use the laptop plugged in. That will stop it from turning off. Been there - done that. Hope that helps! ; )
Nov 05, 2008 | Toshiba Satellite A35-S1592 Notebook
Compaq Evo N610C Notebook Logo
87 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
