Question about RCA HD52W56 52" Rear Projection HDTV
Convergence selection missing from setup menu
I was given instructions from my rca technician to go to setup, scroll down to convergence, and choose auto convergence, but there is no convergence in my menu! What do I do?
  • Anonymous May 09, 2008
    my rca 52" projection tv looks like a 3d comic book and then shuts off
  • RCA Master
  • 8,617 Answers
You have a few capacitors that have blown on the deflection circuit causing the convergence option to be dropped from the menu. I will post the info you need in an hour or two. Or you can email me directly at [email protected]
Posted on Mar 31, 2008
SOURCE:
My convergence will not line up right
if you press menu then scroll down to setup then enter the setup menu does the auto convergence adjustment option still appear under the setup menu options or has it disappeared?
Feb 11, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have ghosting on my 50 inch RCA projection and lines at the top of sreen
convergence issue. Press the menu button then scroll down to setup and enter the setup menu and see if the Auto convergence feature is still listed under setup options or has it disappeared. Let me know and I will assist with what to do to fix the issue.
Mar 18, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
How do I adjust the convergance? I have a shadowing problem
Press menu on the remote then scroll down to setup then enter setup. The auto convergence feature is listed there which will reset it automatically. If auto convergence disappeared from the setup menu then you will need the RCA convergence option missing repair kit from www.tvrepairworld.com which does contain the instructions.
Jun 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
I need to know what convergence board I need and part number. TV is RCA Model HD52W59YX36. Symptom is see 3 d like shadows. When I go to do the covergence adjustment from the setup menu....nothing appears...
You dont need a convergence board. The convergence option missing from the setup menu is a easy cheap repair. www.tvrepairworld.com has the kit called ITC222 & 222A convergence option missing repair kit. It also has the CD with instructions along with the three components that repair that problem.
Mar 27, 2010 | RCA HD52W59 HDTV Projection Television
Have a 56" RCA that i had the user manual for and lost it. i used to do the manual and auto converge. its been so long i forgot how to access it. help?
press menu then scroll to setup the auto convergence features are listed there. If they have disappeared you will need the ITC222A convergence option missing repair kit available from www.tvrepairworld.com
Mar 17, 2010 | RCA R52WM24 52" HDTV Projection Television
Looking for the auto convergence menu on my rca rear projection tv.
Its under the setup section of the on screen menu. If its no longer there then you will need the RCA repair kit called ITC222 and ITC222A convergence option missing repair kit. from www.tvrepairworld.com which has the components and the CD with instructions included with the kit.
Dec 26, 2009 | RCA R52WM24 52" HDTV Projection Television
How get auto convergence on RCA HD52W59YX38 to appear on screen
you can get the repair kit for your RCA at the following link. Its called the ITC222 and ITC222A convergence option missing repair kit, comes with detailed instructions. www.tvrepairworld.com
Sep 04, 2009 | Zenith R56W36 56" Rear Projection...
Convergence
try checking fuse 231 if that blows the convergence option will drop from the menu
Jun 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W56 52" Rear Projection HDTV Logo
207 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
