Question about AOpen (MX4SGI4DN2PRE) Motherboard
Need help can u tell me that how can i define that i/o(128 pin) is bad or good
  • 655 Answers
Hi habiba,
just insert gently to your motherboard, make all other connection well to board, and swicth on.
1). If you hear a long beep, means missing RAM, i.e. either the RAM is not connected properly or your RAM is bad.
2). If you hear just a beep for less than a second, and your computer get started, means your RAM is good....... :))
Thanks
Iqbal
Posted on Mar 31, 2008
HAVE A P0128 IN FORD EXPLORER NEED HELP
Code 128 means the coolant temp sensor is telling the computer the engine is below normal temp. Most common cause is a faulty thermostat.
Sep 16, 2012 | 2006 Chevrolet Tahoe
What colours do i use to link my 128 with my dsc radio
Hi!
From your Owners manual (Page 59) The BLUE wire (Pin 3 NMEA out) from your GPS goes to the NMEA in wire of your DSC radio. The ground pin from your GPS is pin 2 (Black)
Just in case you've misplaced your manual, here's the link you need.
http://static.garmincdn.com/pumac/82_OwnersManual.pdf
Hope this helps and Happy Boating!
Jun 16, 2011 | Garmin GPS 128 Receiver
My recorder show Data format error 1429 1001 ok Can you tell me how to fix this?
Hello I think that the error code that you are getting is because your SD card is not a fast write card, no all the SD cards are compatibles. I recommend this SD card is been tested and definably works an all the Walkabout 5210,5215 or 5220 all Firmware versions http://www.tvps.com/Products/ECS-8000079-128-MB-SD-Memory-Card-for-use-with-Dictaphone---New__ECS-8000079.aspx
Apr 22, 2011 | Dictaphone Walkabout 5220
Engine wont start right up take few minutes engine runs like **** longer it runs better it runs then today that altanater light comes on and battery goes dead so i went to charge it wont charge the...
the alternator is definately bad, if it ran your battery dead like that, and of course as you can tell your battery is trash and needs replaced.. not sure what to tell you on how it runs, considering once it warms up it runs good.
Dec 05, 2010 | Acura TL Cars & Trucks
Our philips dlp tv was getting a dark picture then today no picture but sound then the whole tv shut off and will not come back on do we need to replace the lamp?
Definately sounds like a bad lamp. A lot of times you can look down in the lamp and the filament will be broken or busted up. That would tell you for sure, but even if it is not visibly bad, I would definately try replacing the lamp first. I've changed many of them at our shop, and your description is definately a common symptom of a bad lamp in any dlp.
Jul 29, 2010 | Philips LX-5414 DLP TV
Laptop not chrging even with a good harger.and keeps shuttn down
you could be correct about it being the pin at the charging point. what you need to do is to phone up the company who make your laptop and tell them the problem. they might then say that the laptop might have to be taken away so that they can change the charging point in your laptop and then it should be fine.
Jun 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
Accessories not shutting off, upon exit of car.
sounds like your "pin switch" in the door jamb is either bad or stuck. This is the switch that the car uses to tell the door has been opened. Does the light inside the car light up when you open the drivers door? if not, it is definately the door pin switch. should be a 10-20 dollar part at any gm dealer.
Dec 19, 2008 | 1995 Oldsmobile Aurora
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Dec 09, 2008 | Computers & Internet
Intermittent No Video (6 Year Old TV)
check for cracked solder joints on the coil near of the horizontal output,are between there pins
Sep 05, 2008 | RCA F36650 36" TV
Casio FA-128
how to upgrade Casio FA-128.
Dec 17, 2007 | Casio Boss Business Organizer
AOpen (MX4SGI4DN2PRE) Motherboard Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
