Question about Toshiba 42HM66 42" Projection HDTV
Lamp How do I change the lamp?
  • 2,334 Answers
Check page # 32 and 33 of the user guide.
Posted on Mar 31, 2008
How do I reset the lamp timer for the infocus LP925 projector? Are there other problems that could cause my issue?
hi
this lamp has a small lamp pcb with a chip on it.
have u change the complete module or have just changed the bulb.
if you have just changed the bulb then u have to replace the small fuse on the chip.
this should help to reset the lamp timer!
Apr 07, 2015 | InFocus SP-LAMP-LP9 Projector Lamp for...
I have a mitsubishi 73735 television that is not showing a pcture there is a red lamp light on; on the front of the television does the lamp need changing
Hello, welcome to Fixya!
My question would be; how long have you been using the TV and have you every changed the lamp?
If you have never changed the lamp or if it has been a long time since you changed the lamp, then it means the lamp needs to be changed.
The red lamp staying on, also could mean a power problem. But,in any case, go ahead and change the lamp. Hopefully, it should fix the problem.
Regards.
Nov 03, 2011 | Mitsubishi WD-73735 Television
I replaced the lamp in my Sharp xv-z90u. When I attach the power cord I get a solid green on the power indicator light. I also get a flashing green on the lamp indicator. I tried programming the reset...
First check your bulb properly matched with your projector. After changing the lamp reset the lamp hour (counting from 0hrs). Adjust the osd transparency.
If u set the lamp properly then It may cause the lamp circuit need repair.
Have you got yellow lamp indication before change the lamp? If occur then you have been late to change it. If you used it up to 2500hrs. then this problem may arise. Check those first if everything ok then may be the circuit have some problem, go to the nearest sharp authorize service center or visit website.
Feb 21, 2011 | Sharp Projector Lamp for XV-Z90U
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Lost the lamp cover, changed light and tv wont come on
the lamp cover has a small tab that pushes the lamp switch..the tv will not turn on without..you need it :))
Dec 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
How do I change the lamp in this tv? Do I need to buy just the lamp or lamp with housing?
If you have not changed a lamp before at all, I would suggest that you purchase the lamp plus housing. This will contain complete instructions on how to change the lamp and reset the counter. Keep the instruction sheet and the old housing and you should be able to replace just the lamp the next time.
Dan
Apr 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Projector
Go into the projector menu, OPTION and then select LAMP TIME.
May 30, 2008 | 3M Projector lamp Projector Lamp
Toshiba 42HM66 42" Projection HDTV Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
